[OpenLayers-Users] pdf export: why the request for tile dimensions of 625x458
Robert Buckley robertdbuckley at yahoo.com
Thu Nov 24 01:53:25 EST 2011
Problem: I can´t print any tiles coming from geowebcache!
gridset: 900913
System: Linux Ubuntu 10.04 / tomcat6 / Geoserver 2.1.2
Javscript
// map
var map = new OpenLayers.Map("map", {
        projection: new OpenLayers.Projection("EPSG:900913"),
        displayProjection: new OpenLayers.Projection("EPSG:4326"),
        units: "m",
        maxResolution: 156543.0339,
        maxExtent: new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508.34),
        numZoomLevels: 17,
        controls: [new OpenLayers.Control.MouseDefaults(), new OpenLayers.Control.PanZoomBar(), new OpenLayers.Control.MousePosition(), new OpenLayers.Control.ScaleLine({
            geodesic: true
// layer GWC
var layer_topo = new OpenLayers.Layer.WMS("Topographischekarte", "http://maps.zgb.de/geoserver/gwc/service/wms/", {
        layers: 'zgb:tk50',
        projection: "EPSG:900913",
        format: 'image/png',
        transparent: true,
        singleTile: false
        'buffer': 0,
        'opacity': 1,
        'isBaseLayer': true,
        visibility: true
Geoserver log
2011-11-24 07:39:54,199 ERROR [geowebcache.GeoWebCacheDispatcher] - The requested tile dimensions 625x458 do not match those of the grid set (256x256) http://maps.zgb.de/geoserver/gwc/service/wms
2011-11-24 07:39:54,200 WARN [print.PDFUtils] - Server returned an error for http://maps.zgb.de/geoserver/gwc/service/wms?BBOX=1176787.0%2C6892762.5%2C1181754.1%2C6899536.0&HEIGHT=625&WIDTH=458&map_resolution=75&SERVICE=WMS&REQUEST=GetMap&STYLES=&TILESIZE=%7B%22w%22%3A256%2C%22h%22%3A256%7D&TRANSPARENT=true&VERSION=1.1.1&FORMAT=image%2Fpng&PROJECTION=EPSG%3A900913&format_options=dpi%3A75&LAYERS=zgb%3Atk50&SINGLETILE=false&SRS=EPSG%3A900913: Error (status=400) while reading the image from http://maps.zgb.de/geoserver/gwc/service/wms?BBOX=1176787.0%2C6892762.5%2C1181754.1%2C6899536.0&HEIGHT=625&WIDTH=458&map_resolution=75&SERVICE=WMS&REQUEST=GetMap&STYLES=&TILESIZE=%7B%22w%22%3A256%2C%22h%22%3A256%7D&TRANSPARENT=true&VERSION=1.1.1&FORMAT=image%2Fpng&PROJECTION=EPSG%3A900913&format_options=dpi%3A75&LAYERS=zgb%3Atk50&SINGLETILE=false&SRS=EPSG%3A900913: Bad Request
pdf error attatchment
java.io.IOException: Error (status=400) while reading the image from http://maps.zgb.de/geoserver/gwc/service/wms?BBOX=1091694.4%2C6741760.5%2C1250642.0%2C6958507.0
Can anyone tell me why the mapfish print is requesting tile dimensions  of 625x458?
Yours with thanks,
Rob
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111124/6787127b/attachment.html
