[OpenLayers-Users] Re: Problems with userdefine Popupmarker-Class in OL2.11
Jan Tappenbeck osm at tappenbeck.net
Thu Nov 24 13:34:19 EST 2011
Hi Norbert,
thanks for mailing - but why did you mean this function is the reason? i
deactive the tappenbeck.js the source 3b !
Hallo Norbert,
vielen Dank für die eMail - aber wie kommst Du darauf - ich habe die
tappenbeck.js doch in dem Beispiel [3b - ...only] auskommentiert !
Gruß Jan :-)
m 23.11.2011 19:02, schrieb Norbert Renner:
> Hi Jan,
> I had a look at xmas_test_only.html and it seems like disabling the
> replacement of the OpenLayers Image.initImgDiv function in tappenbeck.js
> would fix this:
> OpenLayers.Tile.Image.prototype.initImgDiv = function() {
> Not sure if this is needed any longer, I haven't tested the POI layer.
> Cheers,
> Norbert
> Am 23.11.2011 12:01, schrieb Jan Tappenbeck:
>> HI !
>> i make several maps to show poi-informations like [1] (use OL 2.9.1).
>> Now i want to change the ol-Version to 2.11 and then i have a big
>> problem. the map tiles will repeat vertical and horizontal. look at [2]
>> I use two special js-files popupmarker.js and tappenbeck.js - they
>> should help to show the popupmarker easier -> but i am not the
>> programmer of these files.
>> i create simple examples in use ol211 - to search the mistake [3b] and
>> in the moment of include the two js-files [2] will happen.
>> because the programmer is uable to help in time so i ask the ol-world if
>> there is someone who can help me for this important problem???
>> regards Jan :-)
>> [1] http://www.tappenbeck.net/osm/maps/deu/index.php?id=1032
>> [2]
>> http://www.tappenbeck.net/forum/openlayer/error_ol_kacheln_20111123.jpg
>> [3a] the simple map without any poi-implementation
>> http://www.tappenbeck.net/osm/maps/deu/xmas_test_ohne.html
>> [3b] [3a]+include the two js-files
>> http://www.tappenbeck.net/osm/maps/deu/xmas_test_only.html
>> [3c] [3b]+add a poi layer
>> http://www.tappenbeck.net/osm/maps/deu/xmas_test_mit.html
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
