[OpenLayers-Users] Custom Build Issue and Questions
Andreas Hocevar ahocevar at opengeo.org
Mon Nov 28 13:11:47 EST 2011
Try to add WMSGetFeatureInfo to the [first] section instead of the
[include] section.
Andreas.
On Mon, Nov 28, 2011 at 7:01 PM, ChiefDan <ChiefDan at gmail.com> wrote:
> I'm trying to roll my own OL library. Currently I am getting a Firebug error
> in my working map of "OpenLayers.Control.WMSGetFeatureInfo is not a
> constructor". I've got it included in my custom build file, and it is in the
> custom library, so I am not sure what is going on there.
> In the .cfg file, I am using only the [include] section to describe the
> components I am using. Is this the correct method, or should I be
> [exclude]ing the things I am not using?
> Also, is there any file ordering I should be implementing, I assume that is
> what the [first] and [last] sections are for, however I am not sure what the
> precedence of files might be.
> My .cfg file is as follows:
> Thanks for any hints/tips!
> Dan
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Custom-Build-Issue-and-Questions-tp7039667p7039667.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
