[OpenLayers-Users] Openlayers on iPad : zoom smoothness
    Henri-Maxime SUCHIER
    hm.suchier at artefacto.fr
    Mon Oct 10 03:12:10 EDT 2011
Bonjour Eric J and merci for your answer J
The fact is that pinch zoom actually works (I just checked that double tap zoom also does). But I can't get the same smoothness as on the example I mentioned. On this example, map zoom precisely follows fingers movement : zooming is continuous. On my work, there seems to be sort of a threshold, zoom is made step by step, and I can't understand why such a difference, as initialization are the same on the example and on my code.
There is no public access to the site currently, but I can send any relevant part of my code if it can provide information on what's the problem.
Thanks again,
HM.
De : Eric Lemoine [mailto:eric.lemoine at camptocamp.com]
Envoyé : dimanche 9 octobre 2011 22:50
À : Henri-Maxime SUCHIER
Cc : users at openlayers.org
Objet : Re: [OpenLayers-Users] Openlayers on iPad : zoom smoothness
On Friday, October 7, 2011, Henri-Maxime SUCHIER <hm.suchier at artefacto.fr> wrote:
> Hello,
> I'm currently working on a website displaying a map fullscreen with openlayers. Main target for this website are iPads, and I thus would like to have smooth interactions with map (such as continuous zooms for example). Here is the way I build my map object :
>                                options = {
>                                                div: "viewer",
>                                                theme: null,
>                                                projection: sm,
>                                                units: "m",
>                                                numZoomLevels: 18,
>                                                maxResolution: 156543.0339,
>                                                maxExtent: new OpenLayers.Bounds(
>        -20037508.34, -20037508.34, 20037508.34, 20037508.34
>                                                controls: [
>        new OpenLayers.Control.TouchNavigation({
>        dragPanOptions: {
>        enableKinetic: true
>                                                layers: [
>        new OpenLayers.Layer.OSM("OpenStreetMap", null, {
>        transitionEffect: 'resize'
> touchMap = new OpenLayers.Map(options);
> I'm wondering why I can't get the same smoothness as on this example http://openlayers.org/dev/examples/mobile-sencha.html where the same controls are used. Is the smoothness here obtained through the use of sencha ? Or is there something to be done with openlayers apart from the init stage ?
The TouchNavigation control should provide "pinch zoom". Does double-tap to zoom in work? And do you have a live example that people could look at?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111010/409c4a41/attachment-0001.html
