[OpenLayers-Users] Re: [Users] [Geoserver-users] Geowebcache in openlayers problem:SOLUTION FOUND!
Matt Priour mpriour at kestrelcomputer.com
Sat Oct 29 20:38:52 EDT 2011
Yep.
The maxExtent is instrumental in setting the grid lattice against which tiles will be requested.
Even if you just have data in a small area, unless you have also defined your cache such that it starts (ie level 0) at that area, then you need to make maxExtent match the maxExtent of the grid system you want.
In this case, you are using the web mercator (EPSG:900913 / EPSG:3857) grid system and the cache itself is not defined as a special subset of that grid system, therefore you need to use the global web mercator grid bounds to hit the cache in any kind of reasonable way.
As you have found the correct solution to limiting users interaction is to use restricted extent.
Matt Priour
Sent: Friday, October 28, 2011 6:40 AM
To: geoserver-users at lists.sourceforge.net ; users at openlayers.org ; users at geoext.org
Subject: Re: [Users] [Geoserver-users] Geowebcache in openlayers problem:SOLUTION FOUND!
after taking my application apart and rebuilding line by line testing the results as I went along I found that when I replaced this line
maxExtent: new OpenLayers.Bounds(772338.842959, 6576723.127095, 1567283.936983, 7127069.730649),
..with
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,20037508, 20037508.34),
...everything lined-up and worked as wanted.
The bounds in the first line where an attempt to restrict my map area to this extent, which were then followed by an restrictedExtent.
Could anyone please explain to me why these bounds had such a devastating affect on the output of my geowebcache layer so that I can understand this better?
yours,
Rob
Von: GeoGEOrge <awmlamp at yahoo.com>
An: geoserver-users at lists.sourceforge.net
Gesendet: 14:55 Donnerstag, 27.Oktober 2011
Betreff: Re: [Geoserver-users] Geowebcache in openlayers problem
I am trying to do something similar, without much success.
you might see if this is related to your problem:
It is, however, very possible to create an OpenLayers application that
caches tiles; just make sure that the tileorigin aligns with the gridset.
from: http://docs.geoserver.org/latest/en/user/geowebcache/using.html
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Geowebcache-in-openlayers-problem-tp6936192p6936229.html
Sent from the GeoServer - User mailing list archive at Nabble.com.
The demand for IT networking professionals continues to grow, and the
demand for specialized networking skills is growing even more rapidly.
Take a complimentary Learning at Cisco Self-Assessment and learn
about Cisco certifications, training, and career opportunities.
http://p.sf.net/sfu/cisco-dev2dev
Geoserver-users mailing list
Geoserver-users at lists.sourceforge.net
Users mailing list
Users at geoext.org
http://www.geoext.org/cgi-bin/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111029/e22422b1/attachment.html
