[OpenLayers-Users] Easy question about adding a map file as a WMS layer from a beginner
Дмитрий Кожух kozhukh at tut.by
Sat Sep 10 07:41:11 EDT 2011
Hello!
I've just started to learn about OpenLayers, MapServer etc.
And I have a question. When I add a Map file as Mapserver layer it works
fine, but when I add it as WMS layer it just displays a background color
(that I have defined in my .map file) and some small unreadable letters.
Probably you would be so kind to help me to find a mistake in my map file or
in html?
Thanks and sorry for asking such a beginner question.
Here is my mapfile:
MAP
  NAME 'World Map'
  # Map image size
  STATUS ON
  SIZE 600 300
  EXTENT -180.0 -90.0 180.0 90.0
  UNITS dd
  SHAPEPATH 'C://GIS/Data/puvWorld'
  IMAGECOLOR 255 255 255
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 0 0
  IMAGEQUALITY 95
  IMAGETYPE png24
  OUTPUTFORMAT
                NAME png
                DRIVER "GD/PNG"
                MIMETYPE "image/png"
                IMAGEMODE PC256
                EXTENSION "png"
  END
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH '/tmp/'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL '/tmp/'
    # WMS server settings
    METADATA
      'wms_title'           'World Map'
      'wms_onlineresource'  '
http://localhost/cgi-bin/mapserv.exe?map=wms.map&'
      'wms_srs'             'EPSG:4326'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See
  END
  LAYER
    NAME 'world_raster'
    TYPE RASTER
    DATA world_raster.tif
    METADATA
      'wms_title' 'world_raster'
      #'queryable' 'true'
      #'wms_srs'   'EPSG:4326'
    END
    STATUS DEFAULT
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
  END
  LAYER
    NAME 'world_adm0'
    TYPE POLYGON
    DATA world_adm0
    METADATA
      'wms_title' 'world_adm0'
      #'queryable' 'true'
    END
    STATUS DEFAULT
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
    CLASS
       NAME 'world_adm0'
       STYLE
         SYMBOL 0
         SIZE 6
         OUTLINECOLOR 0 0 0
       END
    END
  END
END
And here is my html code:
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <style type="text/css">
        #map {
            width: 600px;
            height: 300px;
            border: 1px solid black;
    </style>
    <script src="/openlayers/OpenLayers.js"></script>
    <script type="text/javascript">
        var map, layer;
        function init(){
            map = new OpenLayers.Map( 'map' );
                                                layer = new
OpenLayers.Layer.WMS( "World Map",
http://127.0.0.1/cgi-bin/mapserv.exe?map=C:/GIS/Projects/puvWorld.map"
                                         layers: 'world_raster',
'world_adm0',
                                                     srs: 'EPSG:4326'
                                                /*layer = new
OpenLayers.Layer.MapServer( "World Map",
            "http://localhost/cgi-bin/mapserv.exe", {map:
'C:/GIS/Projects/puvWorld.map'} );*/
            /*layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
                    "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'}
            map.addLayer(layer);
            map.zoomToMaxExtent();
    </script>
  </head>
  <body onLoad="init()">
    <div id="map"></div>
  </body>
</html>
Thank you very much in advance.
Zmicjer Kožuch
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110910/16430c75/attachment-0001.html
