[OpenLayers-Users] Re: Version 2.11 - What happened to the NavToolbar?
Andreas Hocevar ahocevar at opengeo.org
Tue Sep 13 08:45:22 EDT 2011
are you sure that you also updated the theme/ directory when you upgraded to OpenLayers 2.11? The issue you are seeing is a pure css issue, so make sure that you use theme/default/style.css and the theme/default/img folder that ships with OpenLayers 2.11.
Andreas.
On Sep 13, 2011, at 06:16 , magerlin wrote:
> Thanks for your investigation.
> It seems that Openlayers expect the png files to be local on my server:
> http://byogtrafik.ramboll.dk/Furesoe_211/img/pan-panel.png"
> Well none of the png files for the other controls are on my server.
> So is it a bug in openlayers with a faulty url for theese png's?
> Regards Morten
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Version-2-11-What-happened-to-the-NavToolbar-tp6786921p6787227.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
