[OpenLayers-Users] problems with loading speed
boho fnaci4775 at gmail.com
Fri Sep 16 09:47:05 EDT 2011
hi ...
I have 22 layers to be displayed with OpenLayers wms service.
All layers have been displayed properly by the browser, but for loading, the
browser takes a very long time, about almost 3 minutes ...
the question then becomes, is there a way to speed up loading the browser
with OpenLayers?
My code looks like this:
function init(){
		var lon = 99.09668;
		var lat = 2.890000;
		var zoom = 14;
		var map = new OpenLayers.Map('map',{ controls: [] });
		var myStyles = new OpenLayers.StyleMap({
                "default": new OpenLayers.Style({
                    pointRadius: "${type}", // sized according to type
attribute
                    fillColor: "#ffcc66",
                    strokeColor: "#ff9933",
                    strokeWidth: 2,
                    graphicZIndex: 1
                "select": new OpenLayers.Style({
                    fillColor: "#66ccff",
                    strokeColor: "#3399ff",
                    graphicZIndex: 2
		var layer = new
OpenLayers.Layer.WMS('Batas_Kab_region','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'Batas_Kab_region',transparent:true,
format: 'image/gif'}, {isBaseLayer: true});
		var KEC = new
OpenLayers.Layer.WMS('KEC','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'KEC',transparent:true,
format: 'image/gif'}, {isBaseLayer: false});
		var BANK = new
OpenLayers.Layer.WMS('BANK','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'BANK',transparent:true,
		var FASILITAS_IBADAH = new
OpenLayers.Layer.WMS('FASILITAS_IBADAH','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'FASILITAS_IBADAH',transparent:true,
		var FASILITAS_LAINNYA = new
OpenLayers.Layer.WMS('FASILITAS_LAINNYA','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'FASILITAS_LAINNYA',transparent:true,
		var FASILITAS_PENDIDIKAN = new
OpenLayers.Layer.WMS('FASILITAS_PENDIDIKAN','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'FASILITAS_PENDIDIKAN',transparent:true,
		var Jembatan = new
OpenLayers.Layer.WMS('Jembatan','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'Jembatan',transparent:true,
		var KANTOR_CAMAT = new
OpenLayers.Layer.WMS('KANTOR_CAMAT','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'KANTOR_CAMAT',transparent:true,
		var KANTOR_LURAH = new
OpenLayers.Layer.WMS('KANTOR_LURAH','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'KANTOR_LURAH',transparent:true,
		var KANTOR_WALIKOTA_PEMATANGSIANTAR = new
OpenLayers.Layer.WMS('KANTOR_WALIKOTA_PEMATANGSIANTAR','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'KANTOR_WALIKOTA_PEMATANGSIANTAR',transparent:true,
		var Kel_Siantar = new
OpenLayers.Layer.WMS('Kel_Siantar','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'Kel_Siantar',transparent:true,
		var KOTA_PEMATANGSIANTAR = new
OpenLayers.Layer.WMS('KOTA_PEMATANGSIANTAR','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'KOTA_PEMATANGSIANTAR',transparent:true,
		var KTR_PEMERINTAHANPOLISI = new
OpenLayers.Layer.WMS('KTR_PEMERINTAHAN_&_POLISI','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'KTR_PEMERINTAHAN_&_POLISI',transparent:true,
		var REL_KERETA_API = new
OpenLayers.Layer.WMS('REL_KERETA_API','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'REL_KERETA_API',transparent:true,
		var RUMAH_SAKIT_UMUM = new
OpenLayers.Layer.WMS('RUMAH_SAKIT_UMUM','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'RUMAH_SAKIT_UMUM',transparent:true,
		var Siantar_RingRoad = new
OpenLayers.Layer.WMS('Siantar_RingRoad','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'Siantar_RingRoad',transparent:true,
		var SIANTAR_GANG = new
OpenLayers.Layer.WMS('SIANTAR_GANG','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'SIANTAR_GANG',transparent:true,
		var SIANTAR_JALAN_KOTA = new
OpenLayers.Layer.WMS('SIANTAR_JALAN_KOTA','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'SIANTAR_JALAN_KOTA',transparent:true,
		var SIANTAR_JALAN_PROPINSI = new
OpenLayers.Layer.WMS('SIANTAR_JALAN_PROPINSI','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'SIANTAR_JALAN_PROPINSI',transparent:true,
		var SIANTAR_JALAN_NEGARA = new
OpenLayers.Layer.WMS('SIANTAR_JALAN_NEGARA','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'SIANTAR_JALAN_NEGARA',transparent:true,
		var SPBU = new
OpenLayers.Layer.WMS('SPBU','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'SPBU',transparent:true,
		var SUNGAI = new
OpenLayers.Layer.WMS('SUNGAI','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/petaPAD/batasKab.map&;',{layers:'SUNGAI',transparent:true,
		            vlayer = new OpenLayers.Layer.Vector( "Editable" );
            map.addLayer(vlayer);
            zb = new OpenLayers.Control.ZoomBox(
                {title:"Zoom box: Selecting it you can zoom on an area by
clicking and dragging."});
            var panel = new OpenLayers.Control.Panel({defaultControl: zb});
            panel.addControls([
                new OpenLayers.Control.MouseDefaults(
                    {title:'You can use the default mouse configuration'}),
                zb,
                new OpenLayers.Control.DrawFeature(vlayer,
OpenLayers.Handler.Path,
                    {title:'Draw a feature'}),
                new OpenLayers.Control.ZoomToMaxExtent({title:"Zoom to the
max extent"})
map.addLayers([layer,KEC,Kel_Siantar,SUNGAI,Siantar_RingRoad,SIANTAR_GANG,SIANTAR_JALAN_KOTA,SIANTAR_JALAN_PROPINSI,SIANTAR_JALAN_NEGARA,BANK,FASILITAS_IBADAH,FASILITAS_LAINNYA,FASILITAS_PENDIDIKAN,Jembatan,KANTOR_CAMAT,KANTOR_LURAH,KANTOR_WALIKOTA_PEMATANGSIANTAR,KTR_PEMERINTAHANPOLISI,REL_KERETA_API,RUMAH_SAKIT_UMUM,SPBU]);
		map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
I really hope the answer from my friends ...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problems-with-loading-speed-tp6800977p6800977.html
