[OpenLayers-Users] activate / deactivate events
Andreas Hocevar ahocevar at opengeo.org
Sat Sep 17 06:48:32 EDT 2011
Hi Karsten,
in order to unregister events, you cannot use an anonymous function. You would have to do something like the following:
function handler(e) {...}
map.events.register('click', map, handler);
And then you can simply unregister the event using
map.events.unregister('click', map, handler);
Andreas.
On Sep 17, 2011, at 01:45 , karsten vennemann wrote:
> Hi all,
> I have a click event registered on the map:
> map.events.register('click', map, function (e) {
> ... code to be executed...
> How can I activate or deactivate this event ?
> If it was an OpenLayers control called 'infofeature' I could do e.g.
> infofeature.activate();
> and
> infofeature.deactivate();
> How could I achieve this for the above event ?
> Thanks
> Karsten
> Karsten Vennemann
> Terra GIS LTD
> Seattle, WA  98112
> USA
> www.terragis.net
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
