[OpenLayers-Users] even problem with 2.11 - tiles repeat
Jan Tappenbeck osm at tappenbeck.net
Wed Sep 21 05:04:49 EDT 2011
  hi !
i even update to the version 2.11 by 2.9.1 and the problem is - now the
tiles repeat when the map is pan.
i create a little code-modification so you can the the different.
http://www.tappenbeck.net/osm/maps/deu/index.php?id=1032 -> the right
map with 2.9.1
http://www.tappenbeck.net/osm/maps/deu/index.php?id=1032&trace=1 -> the
wrong map with 2.11
the different in the source is only the folder i put the data - when i
change the openlayers.js in the 2.11 folder with the old one everything
is happy. so the mistakte must something by this js-file.
can anybody help me ?
regard Jan :-)
hamburg / lübeck
