[OpenLayers-Users] OpenLayers and GeoWebCache on GeoServer
Dipl. Inf. Carsten Eider eider at fh-bingen.de
Fri Sep 30 02:48:11 EDT 2011
Hi Tobias,
thank you for your hints. But i cannot get it running.
I think my problem has to do with  the origin and size of my
gwc-data,but i cannot grab it where to start.
So my gwc-configuration(layer iis:Luftbilder) is on
http://tc.agroconnect.fh-bingen.de/geoserver211/gwc/service/wmts?REQUEST=getcapabilities
I have setup da demo under http://lw.igreen.fh-bingen.de/igg/olc.html
My errors (see firebug-console):
<ExceptionReport version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://geowebcache.org/schema/ows/1.1.0/owsExceptionReport.xsd"><Exception
exceptionCode="TileOutOfRange"
locator="TILECOLUMN"><ExceptionText>Column 0 is out of range, min: 8
max:8</ExceptionText></Exception></ExceptionReport>
Any ideas?
TIA Carsten
Am 28.09.2011 14:50, schrieb Tobias Reinicke:
> Hi Carsten,
> If you are still looking for working stuff, here is one.
> Attached are 2 documents; wmtscap.html and utils.js
> You obviously also need the openlayers.js file (I used 2.10 for this).
> I assume you are ok with setting these files up in a web server environment.
> It's not the easiest of examples I am afraid, as we use it to test
> between wms / wmts / json. It should be straight forward for you to
> figure it out though.
> The urls that we use take the form of:
> WMTS:
> http://<<servername>>/geowebcache/service/wmts
> WMS:
> http://<<servername>>/geoserver/MPS/wms
> WFS
> http://<<servername>>/geoserver/MPS/ows
> Another thing is, you need to specify the gridSet for the wmts
> request. And you also need to match the resolutions of your openlayers
> map to the resolutions that the gwc is in.
> If you get your wmts get capability document
> http://<<WMTS SERVE>>/geowebcache/service/wmts?REQUEST=getcapabilities
> (this structure also depends on how you have set up),
> somewhere you should see a <tilematrixset></tilematrixset>. The name
> in there is what you need. Ours is called BNG1.
> Your local resolutions you will have had to specify when creating your
> wmts layer, so you should know them.
> As for working with google, I had a layer set up a while ago that
> worked fine with google, but you need to make sure your gwc is in the
> right projection.
> The layer code was:
> var wmtslayer = new OpenLayers.Layer.WMTS({
>                     url: "<<WMTSSERVERURL>>",
>                     layer: "<<LAYERNAME>>",
>                     matrixSet: "EPSG:900913",
>                     matrixIds: matrixIds,
>                     format: "image/png",
>                     style: "_null",
>                     opacity: 1,
>                     isBaseLayer: true
> I hope some of that helps, I'm afraid I can't help you much on the
> setting up gwc side, but if you need any more front end javascript
> help do let me know.
> Regards,
> Toby R
> As for working in google,
> On 27 September 2011 14:57, Dipl. Inf. Carsten Eider <eider at fh-bingen.de> wrote:
>> Hi Geoffrey,
>> thank you for your small hints, but my maxExtent=restrictedExtend=The
>> Google-Earth
>> I would like to add some more baselayers resricted to some parts of
>> germany explicitly as any layer other than normal wms.
>> Any best-practice examples available?
>> Carsten
>> Am 27.09.2011 11:39, schrieb gbrun:
>>> Maybe a tip: in your map, you need to specify the maxExtent property
>>> with the bounds you defined in the projection you used for your
>>> GeoWebCache layers. Afterwards, you can specify the restrictedExtent
>>> of your map with the extent you want to see at the screen. This way,
>>> your map has the same bounds as your GeoWebCache layers: thus, there
>>> are no misalignment for your tiles (they have the same origin) between
>>> the one requested by OpenLayers and the others sent by GeoWebCache.
>>> This tip depends on the way you have configured your GeoWebCache. In
>>> my case, it works with WMS layers (not TMS) and a global projection
>>> defined in GeoWebCache and assigned to each layer.
>>> Geoffrey
>>> Le Tue, 27 Sep 2011 11:13:35 +0200, Dipl. Inf. Carsten Eider
>>> <eider at fh-bingen.de> a écrit:
>>>> Hi list,
>>>> I am looking for working examples where Openlayers uses
>>>> WMTS/TMS/TileCache layers in order
>>>> to get tiles from a geowebcache on a geoserver.
>>>> I have unsuccessfully worked through all examples on openlayers, but
>>>> nothing really works.
>>>> Obviously i don't know how to define the bounded box of my layers.
>>>> Are there any working examples where OL is explicitly connected to a
>>>> geowebcache with maps restricted on defined bounds?
>>>>  TIA Carsten
>> Mit freundlichen Grüßen / Yours faithfully
>> Carsten Eider
>> Dipl. Inf. (FH)
>> Kompetenzzentrum für Innovative Informationssysteme
>> c/o Fachhochschule Bingen / University of applied sciences Bingen
>> Berlinstraße 109
>> 55411 Bingen
>> Tel: +49 (0) 6721 / 409-179
>> Fax: +49 (0) 6721 / 994-251
>> email: eider at fh-bingen.de
>> Internet: iis.fh-bingen.de
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Carsten Eider
Dipl. Inf. (FH)
Berlinstraße 109
55411 Bingen
