[OpenLayers-Users] Saving User Added Map Points
Zac Spitzer
zac.spitzer at gmail.com
Mon Apr 9 06:07:23 EDT 2012
you can access the (added in your case) features in a vector layer as features
http://dev.openlayers.org/docs/files/OpenLayers/Layer/Vector-js.html#OpenLayers.Layer.Vector.features
have a look at this example
http://www.openlayers.org/dev/examples/vector-formats.html
it demonstrates the importing of features from text formats,
to save the features, you will need to export them in a text format,
u want to do the reverse
you can use the format.write() method to get a text version of features
http://dev.openlayers.org/docs/files/OpenLayers/Format-js.html
which then you could use n an ajax call to post the text version back
to the server
z
On Mon, Apr 9, 2012 at 7:08 PM, Imran Rajjad <rajjad at gmail.com> wrote:
> Hi,
> How do you plan to save them? As a file on user side or a database?
> regards,
> Imran
> On Mon, Apr 9, 2012 at 1:58 PM, Alenoosh Baghoomian <hope2end at gmail.com>
> wrote:
>> Hi
>> I have a map that has a google layer , markers layer and vector layer
>> (including point features to display labels of markers) , user can add
>> markers with labels , what I want to do is to save user added geometric
>> points , I have searched alot on KML and GML and seen many examples and also
>> I've read the OpenLayers book, but I couldn't find any suitable example for
>> my case ... Is there a way to solve this ?
>> Here's my code :
>> http://codepad.org/FxI62l57
>> Thanks in advance for your help :)
>> Alenoosh
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> I.R
> Users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
