[OpenLayers-Users] SVG external graphic preserves aspect ratio
Alberto Romeu aromeu at prodevelop.es
Wed Apr 11 06:46:01 EDT 2012
another weird behaviour... In the example [1] the brown boats sometimes
are correctly rendererd when the map is loaded. When zooming the boats
are incorrectly scaled...
[1] http://gis.prodevelop.es/openlayers/svg.html
Alberto Romeu
Prodevelop SL, Valencia (España)
Tlf.: 96.351.06.12 -- Fax: 96.351.09.68
http://www.prodevelop.es
El 11/04/12 12:16, Alberto Romeu escribió:
> Hi,
> I'm trying to apply a SVG external graphic to a points layer. What I
> need is that the graphic size will be scale dependant and will not
> preserve the aspect ratio.
> What I've found is whatever graphicHeight and graphicWidth I set to
> the externalGraphic, the SVG is rendered preserving the aspect
> ratio... If I use png works OK.
> I've published an example [1] of what's happening. The green boats are
> PNG scaled correctly, the brown ones are SVG not scaled correctly,
> both have the same graphicHeight and graphicWidth.
> Am I missing something? Is there a way to use SVG in the way I need?
> Best regards.
