[OpenLayers-Users] Is it possible to edit a LineString after it
has been created and added to a layer?
Curtis Olson
curtolson at gmail.com
Thu Apr 12 12:36:40 EDT 2012
Hi Michael (and everyone else who replied),
Thanks for your quick replies. I'm working on this some more today and
have some follow up questions.
I define my point list in the global scope:
var route_points = new Array();
Then I populate this array with a few points.
Finally I can build the structures and add the result to a layer so I can
see it (and I do see the result.)
lineString = new OpenLayers.Geometry.LineString(route_points);
route_vector = new OpenLayers.Feature.Vector(lineString,null,home_style);
routeLayer.addFeatures( route_vector );
Later I go back and change the location of a point in my route_list array
of points.
route_points[2].lon = newlon;
route_points[2].lat = newlat;
But nothing changes on screen. (for what it's worth, I can recreate all
these structures and add them as a new layer to my map and I do see the new
points in their correct locations, but it's as a new feature along with the
old -- I'm hoping to be able to simply modify the old structure rather than
having to create a new (potentially large/complex) structure each iteration.
I am wondering if the lineString or the Vector constructors use a copy of
the upstream structure rather than a pointer to the structure? In that case
changing my original structure would have no effect.
I wouldn't mind using accessor functions to find the actual data point, but
as I look through the class definitions and inheritance, I don't see any
way to get back to the original point array when starting from a Vector()
or a LineString()?
I'm probably missing something stupid or easy, but I'm just not seeing it?
Am I on the right track or missing by a mile?
Thanks,
Curt.
On Wed, Apr 11, 2012 at 2:22 PM, Michael <mdm at yachtpc.com> wrote:
> Both are doable. You need to do a little digging to be sure you are
> pointing to the correct point when you either change its lonlat or delete
> it. Then you need to redraw the line.
> In my application, I maintained a separate array pointing to the points in
> my line. Possibly not the most efficient, but it worked.
> Michael
> On 4/11/2012 12:08 PM, Curtis Olson wrote:
> Hi,
> I've begun my plunge into openlayers and have a number of things working,
> but I've run into a question that I haven't been able to answer for myself
> from the docs and the mailing list archives.
> I am building a map that will live track an object (for example: my
> aircraft location as I fly in the FlightGear flight simulator.)
> I would like to leave a trail behind myself showing my recent path (say
> for the past 10 seconds or the past 10 minutes.) I am imagining a
> LineString where I can insert new points at one end and remove points from
> the other end -- as my position updates.
> I could create an entirely new LineString and Vector and add that to my
> layer 10x a second (removing the old feature), but I was hoping I could
> just build the linestring once, add it too a layer once, and from then on
> just modify the linestring structure.
> Is something like this possible or am I barking up the wrong tree?
> I have another sort of similar situation where I may want to
> additionally modify the point locations of some of the points in the
> linestring (based on external data coming from the flight simulator.) In
> otherwords I want to reshape the linestring by adjusting the locations of
> individual points. Is anything like this possible?
> I've been hunting through the examples and the documentation and haven't
> stumbled on the appropriate magic yet.
> Any tips or pointers or nudges for an openlayers newbie?
> Thanks,
> Curt.
> Curtis Olson:
> http://www.atiak.com - http://aem.umn.edu/~uav/
> http://www.flightgear.org - http://gallinazo.flightgear.org
> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
Curtis Olson:
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120412/264b9e5a/attachment.html
