[OpenLayers-Users] Capture LayerSwitcher Events
Tobias Reinicke ramotswa at gmail.com
Fri Apr 13 10:32:25 EDT 2012
Not sure if that was the answer you were after Francesco, the way I read
your question was a bit different, and to do what I think you're trying to
do you can use layer event listeners.. which will basically do what you
want.
i.e loadstart and loadend events.
<code>
 layer.events.register("loadstart", layer, function() {
                this.logEvent("Load Start");
or
layer.events.register("loadend", layer, function() {
                this.logEvent("Load End. Grid:" + this.grid.length + "x" +
this.grid[0].length);
</code>
Taken from
http://dev.openlayers.org/releases/OpenLayers-2.11/examples/layerLoadMonitoring.html
which doesn't actually work but look at the source..
Toby
On 13 April 2012 15:18, Fernando Norte <fernando at globalgeo.com.br> wrote:
> With Firebug and jQuery.
> Identify the box of inputs with Firebug and try jQuery methods like
> .each() (for each input) .onChange() (to detect alterations in form).
> Remember: OpenLayers is a JAVASCRIPT framework, so, javascript knowledge
> is gold!
> 2012/4/13 francescoboccacci at libero.it <francescoboccacci at libero.it>
>> Hi all,
>> i'm using OpenLayers.Control.LayerSwitcher and i would like to capture the
>> switch layer event.. How can i do it?
>> Thanks
>> Faancesco
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120413/9e504740/attachment-0001.html
