[OpenLayers-Users] Re: SLDSelect doesn't highlight anything
Phil Scadden p.scadden at gns.cri.nz
Wed Apr 18 17:54:53 EDT 2012
> thanks, but where I should convert the geometry from handler? I'm using
> openstreetmap and all layers I have in epsg:4326. I tried other way to
> select ( http://openlayers.org/dev/examples/getfeature-wfs.html example )
> which I used in one map last year, but with same result, nothing happend and
> firebug is clean :[
Hmm. If the layers on the server have same SRS as the map on the client,
then no conversion is required.
If the getfeature-wfs.html doesnt work, then it suggests something more
fundamental. You do have a working proxy? Have you looked at the request
that OL is sending the server? (ie from the NET tab in Firebug).
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
