[OpenLayers-Users] LoadingPanel and OpenLayers 2.12
Andreas Hocevar ahocevar at opengeo.org
Thu Apr 19 11:58:51 EDT 2012
can you please double check if current master works for you? If this
is the issue I think it is, then it has been fixed on Mach 17th - see
my previous post.
Let us know if you still encounter problems, and please provide an
example or a description of a sequence to test and see the issue.
Andreas.
On Thu, Apr 19, 2012 at 4:30 PM, Franz Buchinger <fbuchinger at gmail.com> wrote:
> Hi,
> I'm using the LoadingPanel addin
> (http://trac.osgeo.org/openlayers/wiki/Addins/LoadingPanel) in conjunction
> with a fairly recent OpenLayers pre2.12 (github master branch from 27th of
> march).
> Unfortunately, the LoadingPanel isn't working reliable any more, sometimes
> it starts blocking my zoom control when no loading action is happening. Any
> hints if i need to update the addin to be 2.12 compatible?
> kind regards,
> Franz
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
