[OpenLayers-Users] Re: SLDSelect doesn't highlight anything
Phil Scadden p.scadden at gns.cri.nz
Thu Apr 19 17:09:55 EDT 2012
Well you are getting an error from the server which obviously means no
data. However, the most obvious thing that stands out from the request
is that it says that SRS is EPSG:4326, however, its clear that the
coordinate you are sending it are NOT EPSG:4326. They look like 900913.
Either transform geometry to 4326 or (if your server supports it), send
the correct srsname in the filter (I think you can do this with
filter.spatial constructor).
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
