[OpenLayers-Users] Long URLs messing up Opacity
Andreas Hocevar
ahocevar at opengeo.org
Fri Apr 20 15:31:42 EDT 2012
yes, it is a regression, and the fix is not trivial (because of the
opacity based tile fade effects on the imgDiv, and the opacity setting
for IFrame tiles that must be made on the IFrame's parent).
A quick and easy workaround would be to override the setOpacity method
on Tile.Image.IFrame to redraw the layer.
Andreas.
On Fri, Apr 20, 2012 at 7:57 PM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Tuesday, April 17, 2012, Andreas Hocevar wrote:
>> Hi,
>> thanks for your report. You found a regression. Can you please create
>> an issue ticket on http://github.com/openlayers/openlayers?
> Andreas. Is this a regression introduced after 2.11. I'm about to release
> rc2. Should this block rc2?
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
