[OpenLayers-Users] Trigger a function before every zoom
Dean Fischer dean at maptia.com
Sun Apr 22 16:18:22 EDT 2012
Hi everyone,
I am trying to animate the growth of some divs which I have positioned
according to lon lat values on the map (like markers but more complex and
more flexible for css manipulation). I want them to grow as a user zooms.
I want to animate them using css transitions but these transitions should
not be applied on panning or dragging. I am therefore injecting the
transition styles into the <head> before changing the size of my divs and
then removing them again after. This works and performs well. The problem
is that I am using the 'zoomend' event and this causes the animation to
start AFTER the map (and all the 'marker' elements) have already moved. For
the effect I want to achieve I need to be able to activate the transitions
before the map moves so that the elements move smoothly appart.
*So.... Why is there not a 'zoomstart' event? And seeing as there is no
event triggered ONLY for the start of a zoom (movestart is triggered for
pan and drag too) can you think of any way to trigger a function at this
time?*
Any help would be really appreciated :)
Dean Fischer
Co-founder at Maptia <http://www.maptia.com>
Twitter        @deanfisch <http://www.twitter.com/deanfisch>
LinkedIn     deanfischer<http://cl.linkedin.com/pub/dean-fischer/48/6a7/41b>
Skype        dkfischer1
You can follow Maptia here
<http://www.facebook.com/maptia>   <http://www.twitter.com/maptia>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120422/a43b05dc/attachment.html
