[OpenLayers-Users] Re: SLDSelect doesn't highlight anything
Phil Scadden p.scadden at gns.cri.nz
Sun Apr 22 17:47:00 EDT 2012
Sorry, should have read more closely. Geoserver doesnt honour srsname in
this context (Mapserver does). You have to convert the geometry to
server native projection at the client end.
eg my code implementing a pt selection using DWITHIN. transformgeometry
function does the work of converting to native.
                 ptSelCtrl[i] = new
OpenLayers.Control.DrawFeature(selectedLayer, OpenLayers.Handler.Point);
                 ptSelCtrl[i].events.register("featureadded", this,
function (e) {
                     clearData();
                     var geom = map.getExtent(); //Done with left side
only to avoid 180 line crossing issues
                     var pt1 = new OpenLayers.Geometry.Point(geom.left,
geom.bottom);
                     var pt2 = new OpenLayers.Geometry.Point(geom.left,
geom.top);
                     transformGeometry(pt1);
                     transformGeometry(pt2);
                     var dist = (pt2.y - pt1.y) / 200;
                     var pfilter = new OpenLayers.Filter.Spatial({
                             type: OpenLayers.Filter.Spatial.DWITHIN,
                             distance: dist,
                             distanceUnits: "meters",
                             value: e.feature.geometry
                      var ly = getLayerNode(combo.value);
                      if (ly.CQL && ly.CQL != '') {
                        var format = new OpenLayers.Format.CQL();
                        pfilter = new OpenLayers.Filter.Logical({
                         type:OpenLayers.Filter.Logical.AND,
                         filters:[format.read(ly.CQL),pfilter]
                     wfsProtocol[combo.value].read({
                         filter: pfilter,
                         callback: processSpatialQuery,
                         scope: strategy
                 mapPanel.map.addControl(ptSelCtrl[i]);
transformGeometry has application-specific code to sort out what map
projection is and what the native projection is, and then transforms with:
         geometry.transform(proj, pproj);
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
