Fwd: [OpenLayers-Users] geojson - additional questions
Paul Meems (Top-X)
p.meems at topx-group.nl
Mon Apr 23 04:37:43 EDT 2012
> Hi Jan,
> I'm also still learning OL ;)
> I'm using
> displayOutsideMaxExtent: true
> I believe it makes it possible to zoom beyond the extent.
> I have no experience with geoJson and how to read it's values.
> But if you've loaded it as a layer you can read the attributes:
> showAttributes(yourLayer.features);
> function showAttributes(features){ if (features.length == 0) { document.getElementById('progress').innerHTML = 'Error no features found!'; return; } var data = '<h2>Number of features: ' + features.length + '</h2>'; data += "<table id='attributeInfo' class='tablesorter'>"; data += getTableHeaders(features[0]); data += '<tbody>'; var featureID; for (featureID in features) { var myFeature = features[featureID]; data += '<tr>'; var key = 0; for(key in myFeature.attributes) { data += '<td>' + formatString(myFeature.attributes[key],2) + '</td>'; } data += '</tr>'; } data += "</tbody></table>"; document.getElementById('attributen').innerHTML = data; }
> I hope it helps.
> Your from Germany, right? Interested in going to the 4-day Open Source GIS
> conference in Velp (near Arnhem)?
> Regards
> Paul Meems
> Organizing the International Open Source GIS conference in The Netherlands:
> http://www.mapwindow.org/conference/2012/
> Op 22 april 2012 18:51 schreef Jan Tappenbeck <osm at tappenbeck.net> het
> volgende:
> Hi !
>> thanks - and i read something about geojson at this weekend and i have
>> some additional questions:
>> * if a bbox is define - is it possible to zoom extant to this by ol ? how
>> is it possible to iterate through the geojson-data -> get a list of all
>> name-properties
>> is it correct to define a name-property like this:
>> { "type": "Feature",
>> "geometry": {
>> "type": "Polygon",
>> "coordinates": [
>> [ [100.0, 0.0], [101.0, 0.0], [101.0, 1.0],
>> [100.0, 1.0], [100.0, 0.0] ]
>> "properties": {
>> "name": "[the name]", <<<<<<<<<<<<---------------
>> "prop1": {"this": "that"}
>> regards Jan :-)
>> Am 20.04.2012 13:05, schrieb Paul Meems (Top-X):
>>> Hi Jan,
>>> I'm using a filter for this:
>>> filter: new OpenLayers.Filter.Comparison({
>>> type: OpenLayers.Filter.Comparison.**EQUAL_TO,
>>> property:"_adresid",
>>> value:"-1"})
>>> and some javascript
>>> function changeFilter(newValue)
>>> wfsLayer.destroyFeatures();
>>> document.getElementById('**progress').innerHTML ="..";
>>> wfsLayer.filter = new OpenLayers.Filter.Comparison({
>>> value: newValue});
>>> wfsLayer.refresh({force: true});
>>> Regards
>>> Paul Meems
>>> Netherlands:
>>> http://www.mapwindow.org/**conference/2012/<http://www.mapwindow.org/conference/2012/>
>>> Op 20 april 2012 11:33 schreef Jan Tappenbeck
>>> <mailto:osm at tappenbeck.net>> het volgende:
>>> hi !
>>> i want to make a map with a function to show streets via a search
>>> dialog.
>>> when a user select a way-name it should be show via a
>>> openlayer-vector.
>>> i only found examples to define elements by the geojson-format and
>>> show all elements in a bundle - but i only want to show the element
>>> with the id=xxxx.
>>> did anyone now an expample for this situation ?
>>> regards Jan :-)
>>> ______________________________**___________________
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> <mailto:Users at lists.osgeo.org>
>>> http://lists.osgeo.org/__**mailman/listinfo/openlayers-__**users<http://lists.osgeo.org/__mailman/listinfo/openlayers-__users>
>>> <http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
>>> Users mailing list
>> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120423/0dde0fbe/attachment.html
