[OpenLayers-Users] Why does OpenLayers.Layer.WMS shows vectors
well and OpenLayers.Layer.OSM does not? (Same code)
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Apr 25 01:35:13 EDT 2012
On Wednesday, April 25, 2012, alexe100 wrote:
> I
> I have a web page that shows points features and one line in the map
> If I use:
> var layer = new OpenLayers.Layer.WMS( "OpenLayers
> WMS","http://vmap0.tiles.osgeo.org/wms/vmap0", {layers: 'basic'} );
> map.addLayer(layer);
> the vectors are well shown.
I guess your vectors are in EPSG:4326. The OSGeo WMS layer is also in
EPSG:4326, so the vectors display correctly onto this layer.
> IF I use this instead:
> var layer = new OpenLayers.Layer.OSM();
> only one point feature is shown on the map and the text font has bad
> quality.
The OSM layer's projection is EPSG:900913 (Spherical Mercator)...
Try adding projection:"EPSG:4326" in your vector layer options, to tell
OpenLayers to transform the vector coords from EPSG:4326 to the map
projection, that is EPSG:900913. This will only work if you use a BBOX or
Fixed strategy in your vector layer. If not please show how you create the
vector layer and add features to it.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120425/d54c3d70/attachment-0001.html
