[OpenLayers-Users] Attibution missing from Bing tilte
Andreas Hocevar ahocevar at opengeo.org
Mon Apr 30 11:52:08 EDT 2012
please check the following:
1) Make sure an OpenLayers.Control.Attribution instance is added to your
map. If you didn't configure a controls array in the map constructor, this
should be the case already, unless
2) Your customized OpenLayers build does not contain
OpenLayers.Control.Attribution.
Andreas.
Re: [OpenLayers-Users] Attibution missing from Bing tilteOn Monday, April
30, 2012, Takako Tucker <Takako.Tucker at bbc.co.uk> wrote:
> Hello,
> I’m using OL 2.11 and loading Bing tile.
> The issue is I can’t seem to see .olControlAttribution div anywhere and
Microsoft Attribution is missing from the map.
> I had a look at OpenLayers.Control.Attribution class, but couldn’t find
any info.
> Does anyone know what it may be hiding it?
> Takako
> http://www.bbc.co.uk
> This e-mail (and any attachments) is confidential and may contain
personal views which are not the views of the BBC unless specifically
stated.
> If you have received it in error, please delete it from your system.
> Do not use, copy or disclose the information in any way nor act in
reliance on it and notify the sender immediately.
> Please note that the BBC monitors e-mails sent or received.
> Further communication will signify your consent to this.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120430/5a3e7bc9/attachment.html
