[OpenLayers-Users] Canvas renderer causing fill in style, map, to be ignored
Rob Hyx
robhyx at gmail.com
Wed Aug 1 06:30:42 PDT 2012
Okay, let me take back what I said last. Adding the additional
renderers ['SVG,'VML,'Canvas'], does fix my problem, but now when I go
to use the Canvas renderer it's not vectorLayer.renderer. Instead I
get the SVG renderer. I see an array vectorLayer.renderers but that's
just an array of Strings. I'm looking at the API and it is not obvious
to me how you can pick your renderer of choice. It seems you must be
able to do it otherwise why would you be able to specify more than
one.
Any ideas?
On Tue, Jul 31, 2012 at 5:40 PM, Robert Hicks <robhyx at gmail.com> wrote:
> Thanks Mike,
> So, I tried adding multiple renderers ['SVG,'VML,'Canvas'] but it fails just
> the same.
> Is there another renderer I should try?
> How do you specify the renderer when the vectors are being drawn? Maybe it's
> defaulting to Canvas for some reason even though it's last in the list.
> On Jul 31, 2012, at 4:33 PM, Mike Ryan wrote:
> I had to alter Canvas.js to fill my layer features with an image (aka
> "hatching"), which is not yet supported. Hatching in general is not
> supported.
> The fillColor worked for me in a Canvas renderer without hacking anything.
> I just pointed out that function to you, because it might help you track
> down the problem. Maybe there's a problem with the Style object you created?
> If you're only having the fillColor problem with the features, just don't
> use the Canvas renderer with them. You don't have to use the same renderer
> for everything.
> -m
> So, is there a bug in OpenLayers that you had to hack in a fix for, or is
> this something that just wasn't supported yet? I need the canvas renderer to
> 'draw' the map tiles to a canvas, but I don't need it for rendering the
> features on the map.
> HYX
> http://hyxspace.com
HYX
http://hyx-music.com
