[OpenLayers-Users] browserNotSupported error upon testing ofrotated label on feature
Donald Kerr donald.kerr at dkerr.co.uk
Sun Aug 5 04:21:19 PDT 2012
Remi,
On viewing the source, there's the following line:
renderers: ["CustomSVG", "VML"] //VML only for IE <= 8, labels are not
rotated
I have tried your link in IE 8, Chrome and Firefox. IE8 works (you don't get
the message) as it uses VML. There others don't as "CustomSVG", I guess, is
not available to your installation of OpenLayers.
When you open the first link, it says, "Create a CustomSVG.js or modify the
existing SVG.js and add the following lines to the Method drawText".
I use rotated text with SVG and have used this solution successfully by
editing svg.js.
Regards,
Donald
-----Original Message-----
[mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of remi
Sent: 05 August 2012 11:12
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] browserNotSupported error upon testing ofrotated
label on feature
I am testing the example for rotating the label of a feature by certain
angle. the example is based on the work by benjamin & tachun in which can be
found on this website:
http://benjamin.preisig.at/rotating-labels-in-openlayers/#comment-43
However, i am encountering an error. The error browserNotSupported pops up
before the map is loaded and the feature is not added at all.
My test sample can be found at this address:
http://ilhamkahfi.com/research/rotated-label/
Hope that somebody can show me some pointer.
thanks
remi
