[OpenLayers-Users] reproject error
Andreas Hocevar
ahocevar at opengeo.org
Sat Aug 18 14:16:56 PDT 2012
The reproject option is deprecated. I strongly recommend to not use
it. If you still want to, you have to include deprecated.js in your
build.
Andreas.
On Sat, Aug 18, 2012 at 8:03 AM, Stephen Davies <sdavies at sdc.com.au> wrote:
> I have a layer defined with reproject:true (see below).
> This generates a javascript error:
> getBoundsFromBaseLayer is not a function.
> Openlayers 2.12 stored locally.
> var trk = new OpenLayers.Layer.WMS( "TRK",
> "http://www.agua.com.au/cgi-bin/mapserv?",
> {map: '/var/www/unit.map',
> layers: 'unit',
> format: 'png',
> transparent: 'true',
> srs: 'EPSG:4326',
> isBaselayer:false
> {'reproject':true}
> Looking in OpenLayers.js I see:
> draw:function(){var a=OpenLayers.Tile.prototype.draw.apply(this,arguments);a?
> (this.layer!=this.layer.map.baseLayer&&
> this.layer.reproject&&(this.bounds=this.getBoundsFromBaseLayer(this.position)),this.isLoading?this._loadEvent="reload":
> (this.isLoading=!
> 0,this._loadEvent="loadstart"),this.positionTile(),this.renderTile()):this.unload();return
> a}
> Stephen Davies Consulting P/L Phone: 08-8177 1595
> Adelaide, South Australia. Mobile:040 304 0583
> Records & Collections Management.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
