[OpenLayers-Users] Catching JSON
Smaran Harihar
smaran.harihar at gmail.com
Mon Aug 20 16:02:59 PDT 2012
Thanks again Phil.
So should I simply copy the jsp code that you have given into a file and
name it proxy.jsp?
And is there any other setting that you want me to do?
Thanks,
Smaran
On Mon, Aug 20, 2012 at 1:56 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> > Did u mean that I should have my py script to which I making the AJAX
> > request in the same dir? Then I already have. Only issue is that, the
> > script is running on port 9000
> > (http://128.196.142.94:9000/info?lat=53.33935546875&lon=-121.99951171875
> > So the domain is same but the ports are different.
> If ports are different, then its cross-domain.
> http://en.wikipedia.org/wiki/Same_origin_policy
> > check that the passed URL is reasonable for the application to call
> > I was able to call py script url (wget
> > "http://128.196.142.94:9000/info?lat=53.33935546875&lon=-121.99951171875
> > -o test.1.log -O test.1), u can run this on terminal and it should
> > fetch you the JSON.
> Then call it via a proxy. XHR has the very tight rules for a good
> reason. By trying to fight browser security, you are on just making life
> difficult for yourself.
> > So, after this, how should I complete the other two parts?
> > 2/ Open an http connection to the passed page
> > 3/ pipe the page content as output.
> This is dependent on what your server and servlet container is. I use
> tomcat and so I have a proxy.jsp to do the work. Source code for
> white-list proxies are on the net. After checking the IP is okay
> (involved for my case), then the jsp code is:
> if (okFlag) {
> BufferedReader brrr = request.getReader();
> String s;
> StringBuffer postContent = new StringBuffer();
> while((s = brrr.readLine()) != null)
> postContent.append(s);
> HttpURLConnection connection = (HttpURLConnection)
> url.openConnection();
> if (postContent.length() > 0) {
> connection.setUseCaches(false);
> connection.setRequestMethod("POST");
> connection.setDoInput(true);
> connection.setDoOutput(true);
> connection.setRequestProperty("Content-Type",
> "application/xml");
> OutputStreamWriter wr = new
> OutputStreamWriter(connection.getOutputStream());
> wr.write(postContent.toString());
> wr.flush();
> wr.close();
> String contentType = connection.getContentType();
> if ("application/vnd.ogc.wms_xml".equals(contentType))
> contentType = "text/xml";
> response.setContentType(contentType);
> InputStream input = connection.getInputStream();
> BufferedInputStream bis = new BufferedInputStream(input);
> ByteArrayOutputStream buf = new ByteArrayOutputStream();
> int result = bis.read();
> while (result != -1) {
> byte b = (byte)result;
> buf.write(b);
> %><%=buf.toString()%><%
> } else {
> %>Access to <%=urlString%> prohibited<%
> You should seek help on writing/getting a proxy from user groups
> dedicated to your particular server arrangement. I cant help you there.
> Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose the
> contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120820/11d50302/attachment.html>
