[OpenLayers-Users] Order/Priority of Control.GetFeature and Control.WMSGetFeatureInfo on click?
Alexandre Dubé adube at mapgears.com
Thu Aug 23 05:43:09 PDT 2012
Hello,
   I'd try your solution proposed below, and manually call the
WMSGetFeatureInfo getInfoForClick or request method.  They need an
OpenLayers.Pixel object, so that'd be what you need to track down from
the GetFeature control.  You might need to override one of its method
for that, as such (untested) :
     OpenLayers.Control.GetFeature.prototype.selectClick = function(evt) {
         // override
         this.lastXY = evt.xy;
         var bounds = this.pixelToBounds(evt.xy);
         this.setModifiers(evt);
         this.request(bounds, {single: this.single});
   and then, in your 'clickout' callback method, you could access what
the last pixel was.  How does that sound ?
HTH,
Alexandre
On 12-08-23 05:35 AM, nica wrote:
> * Deactivating WMSGetFeatureInfo when GetFeature was active, and activating
> WMSGetFeatureInfo when GetFeature registered a clickout. But then the click
> event that triggered GetFeature in the first place doesn't get handed to
> WMSGetFeatureInfo.
Alexandre Dubé
Mapgears
www.mapgears.com
