[OpenLayers-Users] Reproject co-ordinate points
Phil Scadden p.scadden at gns.cri.nz
Sun Aug 26 18:13:20 PDT 2012
its very easy to do the transform in js, especially between 4326 and
900913. eg
                 var lonLat = this.map.getLonLatFromPixel(e.xy);
                 if (this.map.displayProjection) {
                     lonLat.transform(this.map.getProjectionObject(),
                         this.map.displayProjection );
If you look at docs for LonLat, you will see the transform method. It
needs two projection objects. Create one for 4326
eg var p4326 = new OpenLayers.Projection("EPSG:4326");
and then the other will be the map projection. Code might something like:
lonLat = new OpenLayers.LonLat(lon,lat);
lonLat.project(p4326,map.getProjectionObject());
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
