[OpenLayers-Users] Issues with SelectControl
Alexandre Dubé adube at mapgears.com
Mon Aug 27 05:29:47 PDT 2012
   You can try minimizing your code to pin down what the issue is. Read
more about this here:
     http://docs.openlayers.org/help/minimize.html
HTH,
Alexandre
On 12-08-25 08:54 AM, Jamie Johnson wrote:
> I am trying to use the OpenLayers select control in ExtJS 4.1 and have
> 99% of things working, but for some reason when I first create the map
> if I activate the select control I can't actually click any markers
> until I activate another control and reactivate the select control.
> Is there anything that I should be aware of in terms of creation order
> or anything like that which would cause this behavior?
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
