[OpenLayers-Users] Two vector layers and select control
Xavier Mamano (jorix) xavier.mamano at gmail.com
Thu Dec 13 11:21:22 PST 2012
I assume you used ModifyFeature to edit, which also uses a SelectFeature
internally (the last activated is the winner --two ModifyFeature controls in
certain situations can cooperate, but on the same layers--)
Without more details would advise him to use eg a panel to toggle editing
(use methods activate and deactivate of ModifyFeature)
Tondo wrote
> Hi
> I forgot, I tried this without success...
> case 1 - Units layers is above - highlighting (SelectFeature Control)
> works fine, but Draw Layer is not visible -> is not editable.
> case 2 - Draw Layer is above - Editing works fine, but Select Feature
> (hover) wont highlight.
> Regards,
> Tom
View this message in context: http://osgeo-org.1560.n6.nabble.com/Two-vector-layers-and-select-control-tp5021878p5022827.html
