[OpenLayers-Users] vector doesn't display
Gery . gamejihou at hotmail.com
Fri Dec 14 02:19:44 PST 2012
thanks for the answer Matt, OpenGSC and Diego, I'll check the links and see what is going on there
Regards,
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
Date: Wed, 12 Dec 2012 12:11:01 -0600
To: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] vector doesn't display
    You have to actually load the GeoJSON features into the layer.
    First, look at the following examples:
    http://openlayers.org/dev/examples/geojson-reprojected.html
    http://openlayers.org/dev/examples/cartodb-geojson.html
    They both use a Fixed strategy which is the best one if you want to
    load your data once and have it in a static file or known URL.
    You would add your style definition to the vector layer definition
    they present in these examples and then you would have a layer with
    features to be symbolized.
    Matt Priour
    Kestrel Computer Consulting
    On 12/12/2012 6:21 AM, Gery . wrote:
        Hello,
            I have some features in GeoJSON format I want to display, so
            I did this:
            [code]
                  var vectorLayer = null;
                    var vectorStyle =
                        graphicName: 'square',
                        strokeColor: '#222',
                        fillColor: '#222'
                    var styleDefault = OpenLayers.Util.applyDefaults(
                        vectorStyle,
                        OpenLayers.Feature.Vector.style['default']
                    vectorLayer = new OpenLayers.Layer.Vector('search',
                        styleMap: new OpenLayers.StyleMap(
                            'default': styleDefault
                        displayInLayerSwitcher: true
          [/code]
            but they don't appear in the map, my question is if this is
            enough to get the features displayed or do I need something
            else there? if this is enough, I should think that this
            problem is about how the features are being read by OL. In
            fact, this doesn't work either:
            var ll = new OpenLayers.LonLat(feature.geometry.x,
            feature.geometry.y);
            mapPanel.map.setCenter(ll);
            I get:
          feature is not defined
                    var ll = new OpenLayers.LonLat(feature.geometry.x, feature.geometry.y);
            why should this happen? thanks in advance
              necesario.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121214/7bc1e1ca/attachment.html>
