[OpenLayers-Users] OpenLayers.Layer.WMS - using SVG Format?
Matt Priour mpriour at kestrelcomputer.com
Mon Dec 17 10:09:25 PST 2012
Due to the way that IE8 handles SVG, I strongly doubt there is a easy
clean solution for your problem if you must support IE8.
One option would be to force iframe tiles for the layers you want to use
SVG for in IE8.
See the description of how to do this in the deprecation note for the
old WMS.Post layer
https://github.com/openlayers/openlayers/blob/master/lib/deprecated.js#L1884
set 'maxGetUrlLength' to some small number for the desired WMS layers if
you can detect that you are on IE8
Matt Priour
Kestrel Computer Consulting
On 12/17/2012 11:28 AM, Andrew Stewart wrote:
> Hi Harris,
> Thanks for the response - unfortunately we are using Internet Explorer 8 and that is the browser I'm having issues with. I can just use a standard <html> tag without doctype and the svg layer displays properly within Google Chrome, Firefox or Safari. When I use the same code within IE8 I am getting the invalid pink tiles, but when right-clicking and pasting the request into the browser as -
> http://testing/Test_WMS/Request.aspx?LAYERS=Neighbourhood_Label&FORMAT=image%2Fsvg%2Bxml&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A3776&BBOX=8613.8870779406,5792610.7620554,15731.338831386,5799728.2138088&WIDTH=256&HEIGHT=256
> It does show up properly within IE8. Adding the - <!DOCTYPE html> tag gets the pink tiles to dissapear but the OpenLayers Map does not show anything now, any ideas?
> Andrew Stewart
> -----Original Message-----
> From: Harris Hudson [mailto:hhudson at katmandu.org]
> Sent: December 14, 2012 11:38 PM
> To: Andrew Stewart
> Cc: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] OpenLayers.Layer.WMS - using SVG Format?
> Using OpenLayers.Layer.WMS to add a WMS SVG (image/svg+xml) format layer
> should work fine for modern browsers.  I've successfully added WMS SVG
> layers using OpenLayers.Layer.WMS where the layer tiles are added to the
> map based either on the <img> tag or the <iframe> tag.  You might just need
> to have <!DOCTYPE html> at the top of your page for versions of IE that
> support SVG.
> In non standard cases where your WMS produces a non-static or an interactive
> SVG layer, or an SVG layer that has external styling for example, then you
> might consider trying OpenLayers.Layer.WMS.InlineXhtml from the InlineXhtml
> Addin.
> Regards,
> Harris.
>> Hi, just wondering if instead of pushing out an OpenLayers.Layer.WMS as
>> format:image/png I can use svg. My getcapabilities request of my WMS says
>> that is supports SVG with the following -
>> - <GetMap>
>>    <Format>image/png</Format>
>>    <Format>image/jpeg</Format>
>>    <Format>image/svg+xml</Format>
>>    <Format>svgz</Format>
>> However when I declare a WMS layer with svg format it does not show, is
>> there any way to use SVG with a WMS layer? Thanks.
>>   layer_Overview = new OpenLayers.Layer.WMS("Overview Map Layers", wms, {
>>      layers: ["OVERVIEW_County", "OVERVIEW_City_Boundaries",
>> "OVERVIEW_Roads", "OVERVIEW_River", "OVERVIEW_Roads_Highways"],
>>      VERSION: "1.3.0",
>>      format: 'image/svg+xml'
>>      isBaseLayer: true,
>>      displayInLayerSwitcher: false,
>>      singleTile: true,
>>      buffer: 1,
>>      ratio: 1
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/OpenLayers-Layer-WMS-using-SVG-Format-tp5023159.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> [This message has been scanned for security content threats and viruses.]
> [The City of Red Deer I.T. Services asks that you please consider the environment before printing this e-mail.]
> Users mailing list
