[OpenLayers-Users] Re: Change layer on max zoom level
Bennos
benjaminpreisig at gmx.at
Wed Feb 1 11:05:04 EST 2012
I found a solution for this problem, so if anyone ever needs it:
I have to say that i use only the zoom-in and zoom-out buttons for which i
created a panel like in http://openlayers.org/dev/examples/panel.html
I am changing the trigger-behaviour of my zoom-in button to check whether my
base layer is at its maximum zoom level and then change the base layer to
another layer with more zoom levels
//variable to save the zoom plus one, assigned in the zoomend event
var zoomplus=0;
map.events.register('zoomend',this, function(){zoomplus=map.getZoom()+1;});
var panel = new OpenLayers.Control.Panel(); //in my case i am using a panel
and showing only the zoomin and zoomout button
panel.addControls([
new OpenLayers.Control.ZoomIn({
title:'Zoom in',
//overwrite default trigger
trigger: function(){
//osm is my layer with max zoom level: 18, image is with max
zoom level: 20
if
(this.map.baseLayer==osm_tms&&zoomplus==19){this.map.setBaseLayer(this.map.getLayersByName("image")[0]);}
this.map.zoomIn();
new OpenLayers.Control.ZoomOut({title:"Zoom out"})
map.addControl(panel);
To get this behaviour also on double click and mousewheel you have to add
the if also the Navigation-Control:
map.addControl(new OpenLayers.Control.Navigation({
defaultDblClick: function (evt) {
if
(this.map.baseLayer==osm&&zoomplus==19){this.map.setBaseLayer(this.map.getLayersByName("image")[0]);}
var newCenter = this.map.getLonLatFromViewPortPx( evt.xy );
this.map.setCenter(newCenter, this.map.zoom + 1);
wheelChange: function(evt, deltaZ) {
if
var currentZoom = this.map.getZoom();
var newZoom = this.map.getZoom() + Math.round(deltaZ);
newZoom = Math.max(newZoom, 0);
newZoom = Math.min(newZoom, this.map.getNumZoomLevels());
if (newZoom === currentZoom) {
return;
var size = this.map.getSize();
var deltaX = size.w/2 - evt.xy.x;
var deltaY = evt.xy.y - size.h/2;
var newRes = this.map.baseLayer.getResolutionForZoom(newZoom);
var zoomPoint = this.map.getLonLatFromPixel(evt.xy);
var newCenter = new OpenLayers.LonLat(
zoomPoint.lon + deltaX * newRes,
zoomPoint.lat + deltaY * newRes );
this.map.setCenter( newCenter, newZoom );
Cheers
Benjamin
View this message in context: http://osgeo-org.1560.n6.nabble.com/Change-layer-on-max-zoom-level-tp3918789p4356682.html
