Fwd: Re: [OpenLayers-Users] WMS requests executed twice
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Feb 6 06:21:38 EST 2012
Yes, it *was* that issue: with the development version of OpenLayers
layers are always retrieved just once. Thanks Andreas. Just curiosity,
can you give me a pointer to what the problem was?
BTW, I don't get all messages from the OpenLayers Users list in my
mailbox. Had to look up your answers in the archive.
Jan
Andreas Hocevar wrote on Mon, 6 Feb 2012 /04:01:51 EST 2012/
Hi, just to clarify, the issue you are seeing (if it's the issue I think
it is) was fixed *after* 2.11. Andreas.
Hi Andreas,
No, I use OpenLayers 2.11. I see now that it has something to do with my
proxy. All maps are on webservers in an internal network and are
accessed via one proxy.When I run the page on the local server, maps are
retrieved only once. When I access that same server from the outside,
via the proxy, all maps are retrieved twice.
Although this is probably not an OpenLayers problem, I would be
gratefule for suggestions. It took me quite some time to get the proxy
configuration running. It works now, but takes twice as much time as needed.
Jan
Andreas Hocevar wrote on Mon, 23 Jan 2012 04:58:20 -0800: This might be
due to a bug that has been fixed quite some time ago already. Which
version of OpenLayers are you using? Andreas.
On 01/21/2012 09:27 PM, Jan Hartmann wrote:
> Hi all,
> I made a very simple OpenLayers test site, displaying a simple local
> MapServer map as an untiled WMS service. Works fine, but when I look
> in the server log, each OpenLayer GetMap request results in *two*
> identical requests to the server. Can anyone confirm this, and why
> does it happen?
> Jan Hartmann
> Amsterdam
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120206/4a5890e4/attachment.html
