[OpenLayers-Users] Re: SelectFeature when using IE<9 or IE9 Compatibility View
Peter Peterse peter at peterse-uithuizen.com
Tue Feb 7 15:40:09 EST 2012
Hello,
I'm also tried this.
<http://osm.peterse-uithuizen.com/~peter/dragTrouble/index.html>
Now I can't drag an item when I use IE9, IE8 in IETester works.
When I remove the rotation option from the imagestyle (objImageStyle)
then the drag function will work normal.
<http://osm.peterse-uithuizen.com/~peter/dragTrouble/index2.html>
I hope someone can help us..
Regards,
Peter
Op 7-2-2012 14:26, digitalfox schreef:
> Hi Peter,
> Since my project is quite big I've started rebuilding the map in a
> separate project and adding functionality piece by piece. So far It's
> still functional selecting features with external graphic. I'm using
> the following controls at the moment:
>   * LayerSwitcher
>   * Navigation
>   * PanZoomBar
>   * MousePosition
>   * DrawFeature (Point-handler)
>   * SelectFeature
> The feature is styled using a styleMap with a default style for the
> graphics. I will try adding more styles and the lookup for unique
> values and see if it still works.
> View this message in context: Re: SelectFeature when using IE<9 or IE9
> Compatibility View
> <http://osgeo-org.1560.n6.nabble.com/SelectFeature-when-using-IE-9-or-IE9-Compatibility-View-tp4368621p4372490.html>
> Sent from the OpenLayers Users mailing list archive
> <http://osgeo-org.1560.n6.nabble.com/OpenLayers-Users-f3910695.html>
> at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120207/8aa2e73e/attachment.html
