[OpenLayers-Users] RE: Copyright box using Google layers
Henri-Maxime SUCHIER
hm.suchier at artefacto.fr
Wed Feb 8 08:06:35 EST 2012
Hi Toby,
That works for me here also. Thank you very much !
HM.
-----Message d'origine-----
De : Tobias Reinicke [mailto:ramotswa at gmail.com]
Envoyé : mercredi 8 février 2012 13:27
À : Henri-Maxime SUCHIER
Cc : openlayers-users at lists.osgeo.org
Objet : Re: [OpenLayers-Users] Copyright box using Google layers
This is probably because you are calling the google maps api without a specific version no.
Seemingly, the newest api has got a new sort of copyright in it. If you specify <script type="text/javascript"
src="http://maps.google.com/maps/api/js?sensor=false&v=3.6"></script>
then the copyright notice doesn't appear.
I've tried 3.0 and that works fine too.
Remember when specifying a version you have to include the decimal.
Just requesting v=3 will give you the latest (3.7 or 8) which is the latest release.
Toby
On 8 February 2012 09:47, Henri-Maxime SUCHIER <hm.suchier at artefacto.fr> wrote:
> Hello,
> I use Openlayers 2.11 with a Google Maps layer and a few markers on it.
> Since this morning, with no particular changes on my sources, I get a
> copyright box opening on the center of the map whenever I zoom or move
> (a simple white box with a cross to close it at top right, containing
> copyright text). I saw on old threads that the problem already
> appeared on version 2.10, but the problem was fixed upgrading to 2.11
> rc1. Has anyone got this problem using 2.11, and fixed it ? What was the solution ?
> Thanks in advance !
> HM.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
