[OpenLayers-Users] Re: SelectFeature when using IE<9 or IE9
Compatibility View
Peter Peterse
peter at peterse-uithuizen.com
Thu Feb 9 15:05:54 EST 2012
Hello,
I don't think it's the solution. In my last mail I create an example
where the dragFeature worked with IE8 and FireFox, but not with IE9. I
create also the example with removing the rotation, but in my case I
need this functionality.
I think it's a bug of OL, but I don't know where to look for.
Regards, Peter
Op 9-2-2012 14:42, digitalfox schreef:
> *Solution found!*
> After basically two days of constant debugging by removing and adding
> functionality piece by piece, I've figured out what caused the problem.
> As I've stated earlier, we create a StypeMap based on the default
> styles of the Vector-layer and extended with our custom values. While
> debugging, I noticed that if the StyleMap used only the default styles
> of the Vector-layer, the SelectFeature-control would function in all
> versions of Internet Explorer. But if we added our custom styles, the
> SelectFeature-control would fail. So why was this?
> The style-property that was causing the problem was the
> *rotation*-property. We added this to the styles with a value of '0',
> i.e. no rotation as the default value for the property. However, this
> caused our features to not be selectable when using Internenet
> Explorer versions older than 9 (verified using IE9 CV, IE8, IE7).
> Everything works great in FireFox and Chrome though!
> Simply removing the property from the styles solved the problem!
> View this message in context: Re: SelectFeature when using IE<9 or IE9
> Compatibility View
> <http://osgeo-org.1560.n6.nabble.com/SelectFeature-when-using-IE-9-or-IE9-Compatibility-View-tp4368621p4379406.html>
> Sent from the OpenLayers Users mailing list archive
> <http://osgeo-org.1560.n6.nabble.com/OpenLayers-Users-f3910695.html>
> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120209/86e2545e/attachment.html
