Hi, I have tried on another server and I get the same message. It's due to the permission to read only files with registered file extensions. So I can load .xml, but not .gml or .gpx. As a workaround I use to rename my files to somefile.gml.xml. You have to search on your server, where to set the approbiate permissions. Arnd
