[OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.LayerSwitcher
Andreas Hocevar ahocevar at opengeo.org
Tue Feb 14 06:46:07 EST 2012
Oh no, I was hoping you had just added something like the following to
your application css
.olControlLayerSwitcher .dataLbl {
    display: none;
Andreas.
On Tue, Feb 14, 2012 at 12:41 PM, francescoboccacci at libero.it
<francescoboccacci at libero.it> wrote:
> Yes, you are right...
> This is the procedure that i used:
> 1- I modified the file ../lib/OpenLayers/Control/LayerSwitcher.js in this way:
>       - I comment all the line  that contain dataLbl :
>                             * Property: dataLbl
>                             * {DOMElement}
>                             //dataLbl: null,
>                             //this.dataLbl.style.display = (containsOverlays)
> ? "" : "none";
>                             //this.dataLbl = document.createElement("div");
>                             //this.dataLbl.innerHTML = OpenLayers.i18n
> ("Layers");
>                             //OpenLayers.Element.addClass(this.dataLbl,
> "dataLbl");
>                             if (this.ascending) {
>                                                            this.layersDiv.
> appendChild(this.baseLbl);
>                                                            this.layersDiv.
> appendChild(this.baseLayersDiv);
>                                                           //this.layersDiv.
> appendChild(this.dataLbl);
>                                                           this.layersDiv.
> appendChild(this.dataLayersDiv);
>                               } else {
>                                                           //this.layersDiv.
>                                                          this.layersDiv.
>                                                          this.layersDiv.
>                                                          this.layersDiv.
>    after all i recompiled OpenLayers.js file  in this way :
>  ../OpenLayers-2.11/build# ./build.py full.cfg OpenLayers.js
> That's all ... There is anoter way to do that directly into the html file
> after:
>  map.addControl( new OpenLayers.Control.LayerSwitcher({ ....
> just add this line:
> document.getElementsByClassName("dataLbl")[0].innerHTML =""
> That's all.
> Francesco Boccacci
>>----Messaggio originale----
>>Da: ahocevar at opengeo.org
>>Data: 14/02/2012 12.13
>>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>>Cc: <openlayers-users at lists.osgeo.org>
>>Ogg: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
> LayerSwitcher
>>It would be good practice to summarize what was done to solve an
>>issue, because for people finding this in the archive it is annoying
>>to only find "I solved it..." without any hints on HOW.
>>Andreas.
>>On Tue, Feb 14, 2012 at 11:08 AM, francescoboccacci at libero.it
>>> Hi all,
>>> i solved it..
>>> Francesco
>>>>Da: francescoboccacci at libero.it
>>>>Data: 13/02/2012 21.37
>>>>A: <openlayers-users at lists.osgeo.org>
>>>>Ogg: [OpenLayers-Users] Hide Overlay Laben in  OpenLayers.Control.
>>> LayerSwitcher
>>>>Hi all,
>>>>i would like to hide the Overlay Label in my OpenLayers.Control.
>>> LayerSwitcher.
>>>>Is it possible?
>>>>i tried in this way:
>>>>                        dataLbl : "",
>>>>but it doesn't work.
>>>>My html file i add :
>>>><script type="text/javascript" src="OpenLayers-2.11/OpenLayers.js">
>>>>to read directly to the OpenLayer folder in localserver.
>>>>I tried also to comment these lines in:
>>>>../OpenLayers-2.11/lib/OpenLayers/Control/LayerSwitcher.js
>>>> loadContents: function() {
>>>>        //configure main div
>>>>        OpenLayers.Event.observe(this.div, "mouseup",
>>>>            OpenLayers.Function.bindAsEventListener(this.mouseUp, this));
>>>>        OpenLayers.Event.observe(this.div, "click",
>>>>                      this.ignoreEvent);
>>>>        OpenLayers.Event.observe(this.div, "mousedown",
>>>>            OpenLayers.Function.bindAsEventListener(this.mouseDown, this));
>>>>        OpenLayers.Event.observe(this.div, "dblclick", this.ignoreEvent);
>>>>        // layers list div
>>>>        //this.layersDiv = document.createElement("div");
>>>>        //this.layersDiv.id = this.id + "_layersDiv";
>>>>        //OpenLayers.Element.addClass(this.layersDiv, "layersDiv");
>>>>        this.baseLbl = document.createElement("div");
>>>>        this.baseLbl.innerHTML = OpenLayers.i18n("Base Layer");
>>>>        OpenLayers.Element.addClass(this.baseLbl, "baseLbl");
>>>>        this.baseLayersDiv = document.createElement("div");
>>>>        OpenLayers.Element.addClass(this.baseLayersDiv, "baseLayersDiv");
>>>>        //this.dataLbl.innerHTML = OpenLayers.i18n("Overlay");
>>>>        //this.dataLbl.innerHTML = "<u>"+this.getOverlaysTitle()+"</u>";
>>>>        //OpenLayers.Element.addClass(this.dataLbl, "dataLbl");
>>>>        //this.dataLayersDiv = document.createElement("div");
>>>>        //OpenLayers.Element.addClass(this.dataLayersDiv, "dataLayersDiv");
>>>>            this.layersDiv.appendChild(this.baseLbl);
>>>>            this.layersDiv.appendChild(this.baseLayersDiv);
>>>>            this.layersDiv.appendChild(this.dataLbl);
>>>>            this.layersDiv.appendChild(this.dataLayersDiv);
>>>>        } else {
>>>>but it doesn't work. Any suggestion?
>>>>Thanks
>>>>Francesco
>>>>_______________________________________________
>>>>Users mailing list
>>>>Users at lists.osgeo.org
>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Users mailing list
>>Andreas Hocevar
>>OpenGeo - http://opengeo.org/
>>Expert service straight from the developers.
Andreas Hocevar
