[OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.LayerSwitcher
Andreas Hocevar ahocevar at opengeo.org
Tue Feb 14 08:21:54 EST 2012
Just tried with latest OpenLayers from master, and it works fine for
me. Maybe you have stronger selector somewhere that takes precedence?
Andreas.
On Tue, Feb 14, 2012 at 2:05 PM, francescoboccacci at libero.it
<francescoboccacci at libero.it> wrote:
> Hi, i tried int his way but it seem that it doesn't work.
> Do you have any suggestions?
> Thanks
> Francesco
>>----Messaggio originale----
>>Da: ahocevar at opengeo.org
>>Data: 14/02/2012 12.46
>>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>>Cc: <openlayers-users at lists.osgeo.org>
>>Ogg: Re: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
> LayerSwitcher
>>Oh no, I was hoping you had just added something like the following to
>>your application css
>>.olControlLayerSwitcher .dataLbl {
>>    display: none;
>>Andreas.
>>On Tue, Feb 14, 2012 at 12:41 PM, francescoboccacci at libero.it
>>> Yes, you are right...
>>> This is the procedure that i used:
>>> 1- I modified the file ../lib/OpenLayers/Control/LayerSwitcher.js in this
> way:
>>>       - I comment all the line  that contain dataLbl :
>>>                             * Property: dataLbl
>>>                             * {DOMElement}
>>>                             //dataLbl: null,
>>>                             //this.dataLbl.style.display =
> (containsOverlays)
>>> ? "" : "none";
>>>                             //this.dataLbl = document.createElement("div");
>>>                             //this.dataLbl.innerHTML = OpenLayers.i18n
>>> ("Layers");
>>>                             //OpenLayers.Element.addClass(this.dataLbl,
>>> "dataLbl");
>>>                             if (this.ascending) {
>>>                                                            this.layersDiv.
>>> appendChild(this.baseLbl);
>>>                                                            this.layersDiv.
>>> appendChild(this.baseLayersDiv);
>>>                                                           //this.layersDiv.
>>> appendChild(this.dataLbl);
>>>                                                           this.layersDiv.
>>> appendChild(this.dataLayersDiv);
>>>                               } else {
>>>                                                           //this.layersDiv.
>>>                                                          this.layersDiv.
>>>                                                          this.layersDiv.
>>>                                                          this.layersDiv.
>>>    after all i recompiled OpenLayers.js file  in this way :
>>>  ../OpenLayers-2.11/build# ./build.py full.cfg OpenLayers.js
>>> That's all ... There is anoter way to do that directly into the html file
>>> after:
>>>  map.addControl( new OpenLayers.Control.LayerSwitcher({ ....
>>> just add this line:
>>> document.getElementsByClassName("dataLbl")[0].innerHTML =""
>>> That's all.
>>> Francesco Boccacci
>>>>Data: 14/02/2012 12.13
>>>>Ogg: Re: [OpenLayers-Users] Hide Overlay Laben in OpenLayers.Control.
>>> LayerSwitcher
>>>>It would be good practice to summarize what was done to solve an
>>>>issue, because for people finding this in the archive it is annoying
>>>>to only find "I solved it..." without any hints on HOW.
>>>>Andreas.
>>>>On Tue, Feb 14, 2012 at 11:08 AM, francescoboccacci at libero.it
>>>>> Hi all,
>>>>> i solved it..
>>>>> Francesco
>>>>>>Da: francescoboccacci at libero.it
>>>>>>Data: 13/02/2012 21.37
>>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>>Ogg: [OpenLayers-Users] Hide Overlay Laben in  OpenLayers.Control.
>>>>> LayerSwitcher
>>>>>>Hi all,
>>>>>>i would like to hide the Overlay Label in my OpenLayers.Control.
>>>>> LayerSwitcher.
>>>>>>Is it possible?
>>>>>>i tried in this way:
>>>>>>                        dataLbl : "",
>>>>>>but it doesn't work.
>>>>>>My html file i add :
>>>>>><script type="text/javascript" src="OpenLayers-2.11/OpenLayers.js">
>>>>>>to read directly to the OpenLayer folder in localserver.
>>>>>>I tried also to comment these lines in:
>>>>>>../OpenLayers-2.11/lib/OpenLayers/Control/LayerSwitcher.js
>>>>>> loadContents: function() {
>>>>>>        //configure main div
>>>>>>        OpenLayers.Event.observe(this.div, "mouseup",
>>>>>>            OpenLayers.Function.bindAsEventListener(this.mouseUp, this));
>>>>>>        OpenLayers.Event.observe(this.div, "click",
>>>>>>                      this.ignoreEvent);
>>>>>>        OpenLayers.Event.observe(this.div, "mousedown",
>>>>>>            OpenLayers.Function.bindAsEventListener(this.mouseDown,
> this));
>>>>>>        OpenLayers.Event.observe(this.div, "dblclick", this.ignoreEvent);
>>>>>>        // layers list div
>>>>>>        //this.layersDiv = document.createElement("div");
>>>>>>        //this.layersDiv.id = this.id + "_layersDiv";
>>>>>>        //OpenLayers.Element.addClass(this.layersDiv, "layersDiv");
>>>>>>        this.baseLbl = document.createElement("div");
>>>>>>        this.baseLbl.innerHTML = OpenLayers.i18n("Base Layer");
>>>>>>        OpenLayers.Element.addClass(this.baseLbl, "baseLbl");
>>>>>>        this.baseLayersDiv = document.createElement("div");
>>>>>>        OpenLayers.Element.addClass(this.baseLayersDiv, "baseLayersDiv");
>>>>>>        //this.dataLbl.innerHTML = OpenLayers.i18n("Overlay");
>>>>>>        //this.dataLbl.innerHTML = "<u>"+this.getOverlaysTitle()+"</u>";
>>>>>>        //OpenLayers.Element.addClass(this.dataLbl, "dataLbl");
>>>>>>        //this.dataLayersDiv = document.createElement("div");
>>>>>>        //OpenLayers.Element.addClass(this.dataLayersDiv,
> "dataLayersDiv");
>>>>>>            this.layersDiv.appendChild(this.baseLbl);
>>>>>>            this.layersDiv.appendChild(this.baseLayersDiv);
>>>>>>            this.layersDiv.appendChild(this.dataLbl);
>>>>>>            this.layersDiv.appendChild(this.dataLayersDiv);
>>>>>>        } else {
>>>>>>but it doesn't work. Any suggestion?
>>>>>>Thanks
>>>>>>Francesco
>>>>>>_______________________________________________
>>>>>>Users mailing list
>>>>>>Users at lists.osgeo.org
>>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>> Users mailing list
>>>>Andreas Hocevar
>>>>OpenGeo - http://opengeo.org/
>>>>Expert service straight from the developers.
>>Andreas Hocevar
Andreas Hocevar
