R: Re: Re: Re: [OpenLayers-Users] Capture Tile information
francescoboccacci at libero.it francescoboccacci at libero.it
Thu Feb 16 08:56:03 EST 2012
Good solution.. the last question is:
i can capture if an error is occurs during the tile loading (olImageLoadError)
, but is possible to check if the tile is already present in my cache (304
response from server)?
Thanks again ..
Francesco
>----Messaggio originale----
>Da: ramotswa at gmail.com
>Data: 16/02/2012 14.48
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>Cc: <bamerbalazs at gmail.com>, <openlayers-users at lists.osgeo.org>
>Ogg: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>So if you had an OSM layer.
>Register an event on tileloaded on it
> OSMM.events.register("tileloaded", function (e) {
>                var myVar= e;
>and then somewhere in "myVar" you need to check if "olImageLoadError"
>is present. One area could be myVar.element.childNodes[0].innerHTML
>for me that is:
>"<img id="OpenLayersDiv77" style="position: relative; width: 256px;
>height: 256px; " class="olTileImage olImageLoadError" src=....>"
>You can do a text comparison to find if olImageLoadError is in there
>and report something back accordingly.
>I have not ever implemented this nor do I think it is a particularly
>good solution, but it should do what you are after.
>Toby
>On 16 February 2012 13:08, francescoboccacci at libero.it
><francescoboccacci at libero.it> wrote:
>> Hi, can you tell me how look at the css class? can you explain it more
clear?
>> Can you write a simple example ?
>> Thanks in advance...
>> Francesco
>>>Data: 16/02/2012 14.02
>>>Ogg: Re: Re: [OpenLayers-Users] Capture Tile information
>>>No I understand what you are trying to do, but you can,
>>>programatically, look at the css class of every tile that comes in
>>>apparently.
>>>On 16 February 2012 12:53, francescoboccacci at libero.it
>>>> ye..with firebug i can see all requests .. but i'd like to capture the
>> response
>>>> from the server if i'm using the tile from my cache or from server(fresh
>> tile).
>>>> I don't know if is possible but it will be very interesting.Maybe we have
>> to
>>>> work into openlayers code. Thanks
>>>> Francesco
>>>>>Da: bamerbalazs at gmail.com
>>>>>Data: 16/02/2012 13.38
>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>Ogg: Re: [OpenLayers-Users] Capture Tile information
>>>>>Hi Imran,
>>>>>> You can see your http request using FireBug, if you are using FireFox.
>>>>>Yes, but I thought a check during runtime from JavaScript. So that
>>>>>instead of displaying pink tiles, I would write a message about the
>>>>>problem with X layer.
>>>>>best regards: Balázs
>>>>>_______________________________________________
>>>>>Users mailing list
>>>>>Users at lists.osgeo.org
>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>> Users mailing list
