R: Re: Re: Re: Re: Re: Re: [OpenLayers-Users] Capture Tile information
francescoboccacci at libero.it francescoboccacci at libero.it
Thu Feb 16 10:48:41 EST 2012
Can you suggest me some application for that purpose?
Thanks
Francesco
>----Messaggio originale----
>Da: ahocevar at opengeo.org
>Data: 16/02/2012 16.33
>A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
>Cc: <openlayers-users at lists.osgeo.org>
>Ogg: Re: Re: Re: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>On Thu, Feb 16, 2012 at 4:28 PM, francescoboccacci at libero.it
><francescoboccacci at libero.it> wrote:
>> sorry Andreas, my misunderstanding. I would like to try to manage some
>> information about traffic request from the server.
>You should do that on the server really.
>Andreas.
>> That's all. Thanks for your suggestions.
>> Francesco
>>>Data: 16/02/2012 16.20
>>>Ogg: Re: Re: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>>You cannot. All I was saying was that the tileloaded event is also
>>>fired for tiles that come from the cache. Why would you want to know
>>>which tiles come from the browser cache?
>>>Andreas.
>>>On Thu, Feb 16, 2012 at 4:15 PM, francescoboccacci at libero.it
>>>> Hi Adreas, how is possible capture this information?
>>>> I use this code:
>>>> layer.events.register("tileloaded", layer, function() {
>>>>                if (document.getElementsByClassName("olImageLoadError").
>>>> length) {
>>>>                       error+=1;
>>>>  By this way i count the number of tiles that aren't loaded. How can
>> capture
>>>> the tiles coming from the  cache?
>>>> Thanks in advance
>>>> Francesco
>>>>>Data: 16/02/2012 16.08
>>>>>Cc: <ramotswa at gmail.com>, <openlayers-users at lists.osgeo.org>
>>>>>Ogg: Re: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>>No, this is not possible. But the tileloaded event will also fire when
>>>>>the image comes from the cache.
>>>>>Andreas.
>>>>>On Thu, Feb 16, 2012 at 2:56 PM, francescoboccacci at libero.it
>>>>>> Good solution.. the last question is:
>>>>>> i can capture if an error is occurs during the tile loading
>>>> (olImageLoadError)
>>>>>> , but is possible to check if the tile is already present in my cache
>> (304
>>>>>> response from server)?
>>>>>> Thanks again ..
>>>>>> Francesco
>>>>>>>Da: ramotswa at gmail.com
>>>>>>>Data: 16/02/2012 14.48
>>>>>>>Cc: <bamerbalazs at gmail.com>, <openlayers-users at lists.osgeo.org>
>>>>>>>Ogg: Re: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>>>>So if you had an OSM layer.
>>>>>>>Register an event on tileloaded on it
>>>>>>> OSMM.events.register("tileloaded", function (e) {
>>>>>>>                var myVar= e;
>>>>>>>and then somewhere in "myVar" you need to check if "olImageLoadError"
>>>>>>>is present. One area could be myVar.element.childNodes[0].innerHTML
>>>>>>>for me that is:
>>>>>>>"<img id="OpenLayersDiv77" style="position: relative; width: 256px;
>>>>>>>height: 256px; " class="olTileImage olImageLoadError" src=....>"
>>>>>>>You can do a text comparison to find if olImageLoadError is in there
>>>>>>>and report something back accordingly.
>>>>>>>I have not ever implemented this nor do I think it is a particularly
>>>>>>>good solution, but it should do what you are after.
>>>>>>>Toby
>>>>>>>On 16 February 2012 13:08, francescoboccacci at libero.it
>>>>>>>> Hi, can you tell me how look at the css class? can you explain it
more
>>>>>> clear?
>>>>>>>> Can you write a simple example ?
>>>>>>>> Thanks in advance...
>>>>>>>> Francesco
>>>>>>>>>Data: 16/02/2012 14.02
>>>>>>>>>Ogg: Re: Re: [OpenLayers-Users] Capture Tile information
>>>>>>>>>No I understand what you are trying to do, but you can,
>>>>>>>>>programatically, look at the css class of every tile that comes in
>>>>>>>>>apparently.
>>>>>>>>>On 16 February 2012 12:53, francescoboccacci at libero.it
>>>>>>>>>> ye..with firebug i can see all requests .. but i'd like to capture
>> the
>>>>>>>> response
>>>>>>>>>> from the server if i'm using the tile from my cache or from server
>>>> (fresh
>>>>>>>> tile).
>>>>>>>>>> I don't know if is possible but it will be very interesting.Maybe
we
>>>> have
>>>>>>>> to
>>>>>>>>>> work into openlayers code. Thanks
>>>>>>>>>> Francesco
>>>>>>>>>>>Da: bamerbalazs at gmail.com
>>>>>>>>>>>Data: 16/02/2012 13.38
>>>>>>>>>>>A: <openlayers-users at lists.osgeo.org>
>>>>>>>>>>>Ogg: Re: [OpenLayers-Users] Capture Tile information
>>>>>>>>>>>Hi Imran,
>>>>>>>>>>>> You can see your http request using FireBug, if you are using
>>>> FireFox.
>>>>>>>>>>>Yes, but I thought a check during runtime from JavaScript. So that
>>>>>>>>>>>instead of displaying pink tiles, I would write a message about the
>>>>>>>>>>>problem with X layer.
>>>>>>>>>>>best regards: Balázs
>>>>>>>>>>>_______________________________________________
>>>>>>>>>>>Users mailing list
>>>>>>>>>>>Users at lists.osgeo.org
>>>>>>>>>>>http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>>>>>>>> Users mailing list
>>>>>> Users mailing list
>>>>>Andreas Hocevar
>>>>>OpenGeo - http://opengeo.org/
>>>>>Expert service straight from the developers.
>>>> Users mailing list
>>>Andreas Hocevar
>Andreas Hocevar
