[OpenLayers-Users] Drawing a point feature with image and background color..
jkm rifins at gmail.com
Fri Feb 17 12:08:29 EST 2012
Uhm..
But.. as seen in this link..
http://docs.openlayers.org/library/feature_styling.html
"fillColor
Default is #ee9900. This is the color used for filling in Polygons. It is
also used in the center of marks for points: the interior color of circles
or other shapes. It is not used if an externalGraphic is applied to a
point."
I'm drawing features with images defined by the externalGraphic property..
Then.. I can't use the fillColor.. ?
Or is there any other way to draw the feature withous using externalGraphic?
Thanks...
2012/2/17 Carlos Krefft <ckrefft at rsmas.miami.edu>
> Here are the possible values:****
> http://docs.openlayers.org/library/feature_styling.html#style-properties**
> *From:* openlayers-users-bounces at lists.osgeo.org [mailto:
> openlayers-users-bounces at lists.osgeo.org] *On Behalf Of *Carlos Krefft
> *Sent:* Friday, February 17, 2012 11:40 AM
> *To:* 'jkm'; users at openlayers.org
> *Subject:* RE: [OpenLayers-Users] Drawing a point feature with image and
> background color..****
> Use fillColor.****
> fillColor: "#FF5500",****
> fillOpacity: 0.7,****
> Carlos K.****
> [mailto:openlayers-users-bounces at lists.osgeo.org] *On Behalf Of *jkm
> *Sent:* Friday, February 17, 2012 5:58 AM
> *To:* users at openlayers.org
> *Subject:* [OpenLayers-Users] Drawing a point feature with image and
> Hi, ****
> I would like to know if it is possible to draw a point feature with a
> I define a style like that:****
> ImgStyle = {****
>         externalGraphic: imgURL,****
>         label: text,****
>         labelXOffset: "0",****
>         labelYOffset: "-10",****
>         fontColor: txt_colfont,****
>         fontSize: "10px",****
>         fontFamily: "Arial",****
>         fontWeight: "bold",****
>         pointRadius: 10,****
>         labelAlign: "cm",****
>         labelPadding: "3px",****
>         labelBackgroundColor: txt_colback,****
>         labelBorderColor: "#cfcfcf",****
>         labelBorderSize: "1px"****
> And what I would like to do, is draw a background to the image..****
> By now, I'm drawing two elements in the same position, one is the point
> with the externalGraphic, and the other one is the same but without the
> externalGraphic and with a background color.. With this I can see the
> effect of a background under the image..****
> But, I would like to draw as a unique element... Because I'm loading a
> large amount of markers to the map.****
> And also, I would like to apply a cluster strategy to the layer.. And
> drawing the background and the image as separate features modifies the
> clustering..****
> Thanks!****
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120217/772d9d9e/attachment.html
