[OpenLayers-Users] Drawing a point feature with image and background color..
jkm rifins at gmail.com
Fri Feb 17 12:53:07 EST 2012
Ohps sorry! You are right! I made a confusing question..
What I would like.. is draw only one feature..
This feature should represent the kind of item (represented by the
externalGraphic) and how much critical is the item (represented by
background color from green to red)..
By now, i'm drawing in two separate features on the same position (One with
externalgraphic, and the other with fillColor).. But I'm doing in this way,
because i can't find the way to draw a unique feature..
You can see that my english is not as good as i would like..  :)
Thanks again..!
2012/2/17 Carlos Krefft <ckrefft at rsmas.miami.edu>
> “I'm drawing features with images defined by the externalGraphic
> property.. Then.. I can't use the fillColor.. ?”****
> You cannot use fillColor with an externalGraphic as it says in the
> documentation . But your original question states you will be using TWO
> features “I'm drawing two elements in the same position”.****
> So use fillColor for your background feature and externalGraphic for your
> foreground feature.****
> “Or is there any other way to draw the feature withous using
> externalGraphic?”****
> Yes, you can simply omit the externalGraphic and the feature will draw
> without the a graphic, just with the style.****
> Carlos K.****
> *From:* jkm [mailto:rifins at gmail.com]
> *Sent:* Friday, February 17, 2012 12:08 PM
> *To:* Carlos Krefft
> *Cc:* users at openlayers.org
> *Subject:* Re: [OpenLayers-Users] Drawing a point feature with image and
> background color..****
> Uhm..****
> But.. as seen in this link..****
> http://docs.openlayers.org/library/feature_styling.html ****
> "fillColor****
> Default is #ee9900. This is the color used for filling in Polygons. It is
> also used in the center of marks for points: the interior color of circles
> or other shapes. It is not used if an externalGraphic is applied to a
> point."****
> I'm drawing features with images defined by the externalGraphic property..
> Then.. I can't use the fillColor.. ?****
> externalGraphic?****
> Thanks...****
> 2012/2/17 Carlos Krefft <ckrefft at rsmas.miami.edu>****
> Here are the possible values:****
> http://docs.openlayers.org/library/feature_styling.html#style-properties**
> *From:* openlayers-users-bounces at lists.osgeo.org [mailto:
> openlayers-users-bounces at lists.osgeo.org] *On Behalf Of *Carlos Krefft
> *Sent:* Friday, February 17, 2012 11:40 AM
> *To:* 'jkm'; users at openlayers.org
> *Subject:* RE: [OpenLayers-Users] Drawing a point feature with image and
> Use fillColor.****
> fillColor: "#FF5500",****
> fillOpacity: 0.7,****
> Carlos K.****
> [mailto:openlayers-users-bounces at lists.osgeo.org] *On Behalf Of *jkm
> *Sent:* Friday, February 17, 2012 5:58 AM
> *To:* users at openlayers.org
> *Subject:* [OpenLayers-Users] Drawing a point feature with image and
> Hi, ****
> I would like to know if it is possible to draw a point feature with a
> I define a style like that:****
> ImgStyle = {****
>         externalGraphic: imgURL,****
>         label: text,****
>         labelXOffset: "0",****
>         labelYOffset: "-10",****
>         fontColor: txt_colfont,****
>         fontSize: "10px",****
>         fontFamily: "Arial",****
>         fontWeight: "bold",****
>         pointRadius: 10,****
>         labelAlign: "cm",****
>         labelPadding: "3px",****
>         labelBackgroundColor: txt_colback,****
>         labelBorderColor: "#cfcfcf",****
>         labelBorderSize: "1px"****
> And what I would like to do, is draw a background to the image..****
> By now, I'm drawing two elements in the same position, one is the point
> with the externalGraphic, and the other one is the same but without the
> externalGraphic and with a background color.. With this I can see the
> effect of a background under the image..****
> But, I would like to draw as a unique element... Because I'm loading a
> large amount of markers to the map.****
> And also, I would like to apply a cluster strategy to the layer.. And
> drawing the background and the image as separate features modifies the
> clustering..****
> Thanks!****
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120217/16ded39a/attachment.html
