[OpenLayers-Users] Re: Drawfeature question
Robert Sanson
Robert.Sanson at asurequality.com
Thu Feb 23 17:45:47 EST 2012
Hi Matt
The DrawFeature control should be activated as soon as I run the newcrop function, as it activates dpoly, which is the DrawFeature control. I would expect the circle symbol to appear as soon as I move my mouse over the map, as it does in the snap example (albeit squares) at:
http://openlayers.org/dev/examples/snapping.html
(BTW I have a separate snap control which I have as a menu option on the toolbar above the map which activates snapping.)
In my case, the circle symbol only appears after the first point is drawn.
Many thanks,
Robert
>>> sqgs <mxxerr at yahoo.com> 24/02/2012 11:33 a.m. >>>
I am not qualified to answer your question (I am new to openlayers), but I
think you have a conflict in drawfeature control
You have a drawfeature Icon (displayClass: "olControlDrawFeaturePoint"),
which will activate drawfeature when it is pressed, and at the same time,
you have a toggle function newcrop(), which specify which control is
activated.
For using icons, you can check this example:
http://openlayers.org/dev/examples/wfs-snap-split.html
For using toggle function, you can check this example:
http://openlayers.org/dev/examples/modify-feature.html
Matt.
View this message in context: http://osgeo-org.1560.n6.nabble.com/drawfeature-question-tp4474203p4500304.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
