[OpenLayers-Users] Initializing hidden map
Christian Ledermann
christian.ledermann at gmail.com
Fri Feb 24 01:38:34 EST 2012
maybe this could help:
http://www.coactivate.org/projects/collectivegeo/lists/collectivegeo-discussion/archive/2011/06/1309333225166
On Thu, Feb 23, 2012 at 11:25 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> Not very hopeful as I battled this for months. Making it work in all
> browsers (esp IE) was nightmare and in the end abandoned the design.
> However, if you are going to persist, then these hints might help.
> - try zoomtoextent in the tab activation code
> - try delaying creating the map till tab activation.
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Best Regards,
Christian Ledermann
Nairobi - Kenya
Mobile : +254 702978914
If you save the living environment, the biodiversity that we have left,
you will also automatically save the physical environment, too. But If
you only save the physical environment, you will ultimately lose both.
1) Don’t drive species to extinction
2) Don’t destroy a habitat that species rely on.
3) Don’t change the climate in ways that will result in the above.
