[OpenLayers-Users] select multiple features with a click
Pierre Giraud pierre.giraud at camptocamp.com
Fri Feb 24 06:25:09 EST 2012
Unfortunately, the SelectFeature relies on OL.Handler.Feature for
selection by click. This handler isn't able to do multiple selection
due to DOM events limitations.
The following is kind of a hack but the following should work (tested
quickly in the select-feature.html example).
The trick is to disable the feature handler, and to use the select by
box even if the user doesn't drag a box.
The problem is that you won't be able to navigate the map while using
this control. There may be a better a solution.
var vectors = map.getLayersByName('Vector Layer')[0];
SelectMultipleControl = OpenLayers.Class(OpenLayers.Control.SelectFeature, {
    selectBox: function(position) {
        if (position instanceof OpenLayers.Pixel) {
            position = new OpenLayers.Bounds(position.x, position.y,
position.x, position.y);
        OpenLayers.Control.SelectFeature.prototype.selectBox.call(this,
position);
var control = new SelectMultipleControl(vectors, {
    box: true,
    multiple: true,
    clickout: true
map.addControl(control);
control.activate();
control.handlers.feature.deactivate();
Pierre
On Thu, Feb 23, 2012 at 11:03 PM, Jim White <jbw2003 at earthlink.net> wrote:
> I have a vector layer of points with images. I want to click on the map and
> select one or more features if several points are close together.
>  var select_control = new OpenLayers.Control.SelectFeature(vector_layer,
>            {"onSelect": test,
>               "multiple": true});
> This doesn't seem to work. It selects one feature, but not two if two points
> are close together. How to do this?
> Jim White
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Pierre GIRAUD
Géomaticien, Analyste
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 93
Mail : pierre.giraud at camptocamp.com
http://www.camptocamp.com
