[OpenLayers-Users] OSM base layer + WMS overlay
Eric Lemoine eric.lemoine at camptocamp.com
Sun Feb 26 11:01:08 EST 2012
On Thursday, February 23, 2012, François Van Der Biest wrote:
> Hi guys,
> This very simple code used to work :
> map = new OpenLayers.Map({
>    layers: [new OpenLayers.Layer.OSM()]
> map.addLayers([
>    new OpenLayers.Layer.WMS("test", "/geoserver/wms", {
>        layers: "dept"
>        isBaseLayer: false
> It does not anymore : the result is a WMS layer whose div is empty.
> To fix it, I've had to set the map maxExtent to new OpenLayers.Bounds(
>    -128 * 156543.03390625,
> I find it redundant, since this maxExtent is already defined in
> OpenLayers.Layer.XYZ (which is extended by OpenLayers.Layer.OSM).
> Am I doing something wrong or is it a bug ?
This sounds like a serious regression, probably caused by
<https://github.com/openlayers/openlayers/pull/219>. Do you use a built
version of OL or do you observe the problem also when using OL's autoloader?
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120226/cdcb662e/attachment.html
